Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-04-2009, 11:42 PM
03F350GUY 03F350GUY is offline
03F350GUY is starting off with a positive reputation.
Running no cat on your diesel ruins your engine!?!? Please read and respond
I have a '03 F-350 6.0 and was pretty set on getting a MBRP 4" turbo back exhaust with the cat cut off pipe and then i read somewhere from a guy saying that running no cat can cause the engine to run bad and mess the engine up because of the computer receiving some sort of signal to the engine effected by not having a cat. Is this some Eco nut's bs rambling or is there any truth to this....anyone know anything about negative effects from running no cat?
thanks,
Chris
  #2 (permalink)
Old 10-04-2009, 11:52 PM
flamebuster flamebuster is online now
flamebuster is gaining momentum as a positive member of FTE. flamebuster is gaining momentum as a positive member of FTE.
Havn't heard of any ill effects for the engine, only for those who have to pass an emission test and some feel the cat still dosn't help. I baught mine with no cat. and the 4" exhaust and have no plans of changing it.. I am sure someone will chime in with more technical advice.. And welcome to FTE these guys and gals are great.
__________________
DOUG
2004 F-350 Super Duty Crew King Ranch . 6.0 psd...coolant, filter,egr. cooler delete, ccv. reroute, slotted and drilled rotors,kitty ran away, air bags,leveling kit, progigy,piaa lights,
2003 EXP; All stock Wifes ride!!!
2006 2500HD gmc.All stock work trk.
  #3 (permalink)
Old 10-05-2009, 12:59 AM
Egmonster Egmonster is offline
Egmonster is starting off with a positive reputation.
That is BS. Gas engines require "back pressure" to run properly, but diesels do not.
  #4 (permalink)
Old 10-05-2009, 02:41 AM
matty169 matty169 is offline
matty169 is gaining momentum as a positive member of FTE.
BS all the way.......
You DO NOT NEED A CAT. THE END. And it helps to get rid of it.
  #5 (permalink)
Old 10-05-2009, 03:53 AM
ford7379trucks ford7379trucks is offline
ford7379trucks is starting off with a positive reputation.
cats only harm engines they do nothing for them but cause high egts. if you can get away with it get rid of it.
__________________
2003 F250SD 4x4 6.0L 5 Speed Auto 12/03 flash
With a F250 and a 30-06
Who needs a radio when you got a turbo diesel?
The only difference between o bama and osama is BS.
FUBO
  #6 (permalink)
Old 10-05-2009, 04:05 AM
Wow you guys sure hate cats.
  #7 (permalink)
Old 10-05-2009, 04:21 AM
ya id rather have a bully dog. haha no really a SCT
__________________
FUBO
  #8 (permalink)
Old 10-05-2009, 05:19 AM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
2003 Ford F-250
ljutic ss is gaining momentum as a positive member of FTE.
You can get rid of the cat, but you better store it for when your state kicks in emissions inspection.
  #9 (permalink)
Old 10-05-2009, 08:24 AM
fgallant's Avatar
fgallant fgallant is offline
fgallant is starting off with a positive reputation.
What can you guys tell me about removing it and the advantages? My 04 SD rig is bone stock but very well maintained but anything I can do to enhance performance I will consider??
  #10 (permalink)
Old 10-05-2009, 08:48 AM
tex25025's Avatar
tex25025 tex25025 is online now
tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE. tex25025 has a great reputation on FTE.
Quote:
That might have been true a couple of decades ago, but that isn't true now. I haven't a drastic decrease in EGTs when I first removed the cat. I had a turbo-back 4" exhaust first, but I left the cat in. There was reduction in EGT's, but that was because I went with a bigger system(by the way, if you don't plan on running more then just a tuner, don't get bigger then 4", you'll actually lose low end power if you go bigger because you're not flowing enough fuel and air to support it with just a tuner). After I removed the cat, there was zero(I repeat, zero reduction(that may very from person to person) in EGTs, just more sound that is the biggest benefit of removing the cat(this happens across the board).
These cats aren't the HP robbing, restrictive cats that my parents grew up with. Had the EPA allowed the EGR valve to mature naturally those probably wouldn't be the headache that they are for diesels, same with DPF and next Urea.
__________________
'06 6.0L Turbo Diesel King Ranch DRW 4.30 Gears
Bunch of goodies that add up to 508hp/721ftlbs
2010 Platinum F-150 3.55 Gears
Nothing but stock
  #11 (permalink)
Old 10-05-2009, 08:56 AM
Plugman's Avatar
Plugman Plugman is offline
Plugman is starting off with a positive reputation.
Quote:
They already have in earlier posts: By removing back pressure of a turbo charged engine it helps run better. Think of it this way, the more cool air you can flow the more efficient your turbo works, so intake and full exhaust = better air flow and higher performance.
__________________
2004 Excursion Limited
4" Lift, 35" BFG's
SCT X3 w/ Looney Street tune
Airaid Intake, Zoodad Mod
4" Mbrp turbo back exhaust w/5" tip
Egr Delete, ARP Headstuds
  #12 (permalink)
Old 10-05-2009, 09:04 AM
tex25025's Avatar
Quote:
Originally Posted by Plugman View Post
so intake
Actually this is a big no-no when it comes to the 6.0. A/m intakes do not flow more then the stock intake until you hit 3700 rpms. Peak HP and TQ are at 3300 and 2000 rpms respectively. In order to get the benefit of flowing more air you would have to raise the peak hp/tq rpms and you can only do that thru injector and/or turbo upgrades, not with a tuner alone. 90% of the people out there waste their money on this mod, not only because they don't flow more, but they have also been shown not to filter as much as well.
Now if you want to get the intake because you want it, think it looks cool, and/or cleaning and re-installing that those might have some merit depending on where you stand on those issues, but they do not benefit the majority of people out there with regard to air flow and filtration over the stock unit. If we were talking about the 7.3 then you would have something, but not the 6.0.
__________________
Nothing but stock
  #13 (permalink)
Old 10-05-2009, 09:36 AM
janton01 janton01 is offline
janton01 is starting off with a positive reputation.
Just a quick question, here in NJ they look at the exhaust sys for mods now. Is it workable to empty out the cat and reinstall the shell. I had the front connect apart but could not get the rear connection to seperate. Will roding out the material inside the cat provide the same reduction in restriction or only total removal. No other mod's other than a cooling system filter.
  #14 (permalink)
Old 10-05-2009, 09:53 AM
yz400f yz400f is offline
yz400f is starting off with a positive reputation.
My 05 scurge has a Cat.
There ain't nothing in it but air though!
Take it out, get a long bar and an hammer and get at it. ( also need a block of wood to put the end down on.)
Takes an hour or so, but it is not that hard to skin that cat.
  #15 (permalink)
Old 10-05-2009, 10:19 AM
Thanks, getting it off is the fun part that aft connection has been there since new likely so it is well stuck. Back to work at it, guess a torch should help. Thanks again.
Tags
60 , bad , cat , cats , cut , deleting , diesel , diesels , dpf , harm , no , rid , versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
