Restoring 1949 Ford F3 - Page 21 - Ford Truck Enthusiasts Forums
  #301
Old 12-05-2013, 12:25 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
What is the serial number? That will tell what engine it originally had.
  #302
Old 12-05-2013, 12:56 PM
Moe Craig's Avatar
Moe Craig Moe Craig is online now
Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.Moe Craig has a great reputation on FTE.
Looking forward to more pics of your wife's new ride
  #303
Old 12-05-2013, 01:01 PM
subaruguy72 subaruguy72 is offline
subaruguy72 is starting off with a positive reputation.
Serial number same as Vin..? I see vin on Firewall high on passenger side...?
I will get it and post here....thanks guys.... Wife loves Red, so she is torn...the blue looks really good too....and is a recent home done paint job...looks great form 15-20ft...lol...bit rough up close, but solid, and will not rust....thinking we might leave it blue for now, make it road worthy, and start collecting the little fun stuff for it....
If I were wanting to return it to Flat head original status...is there a good Auto tranny out there or adapter available to run one..? Wife has bad knee, and Clutch will not be good for her to drive...
  #304
Old 12-05-2013, 01:27 PM
Moe Craig's Avatar
These trucks were built before they had VINs on vehicles, the serial number is what they used for ownership and registration. So the number on the tag is correct. You should also find it stamped up on the passenger side of the frame near the original motor mount and on the glove box door. Did you get a title with her?
With it being a 49 V8 F3 it should start with like
98RY*****
9= 1949 or 50
8R = V8
Y = F3
the rest is you serial number down the line
  #305
Old 12-05-2013, 02:50 PM
Mine is an F2...
Here is the Serial number....
9 8 R D 3 9 0 4 3 4 K C
So it appears V8 was stock... it has a 4 speed in the bed , can I assume that is original as well.....?
I am torn between keeping the 302 in it or rebuilding the Flat Head...
I think they are the Shiz....But it is the Wifes truck, so it is Her decision In the end....Might rebuild the flat head with my Boy and Daughter , just to do it, then sell it or Stuff it into something else..
Breakdown of my Serial is much apreciated...
John
  #306
Old 12-05-2013, 05:13 PM
Moe Craig's Avatar
KC (Kansis City) is the plant that yours was built in. Serial number sound high enough to be a 1950, someone else will chime in with more info. Also take a look at this http://www.ford-trucks.com/forums/42...n-cut-off.html
  #307
Old 08-03-2014, 11:55 AM
Saivarnos Saivarnos is offline
Saivarnos is starting off with a positive reputation.
Don't know if anyone has posted this to the thread yet
But her is a link to a company in New York who has a catalog of early ford replacement parts for pickups the catalogue is pretty comprehensive http://www.earlyford.com/images/49-59%20catalog.pdf
Good luck!
  #308
Old 09-23-2014, 04:50 PM
CarlH CarlH is offline
CarlH is starting off with a positive reputation.
Rear bumper for F3 Express
Is the rear bumper for the F3 Express pickup the same as the one for the F1?
Also, is the tailgate chain system the same as the F1?
It appears that MACs catalogs seldom mention the F3.
CarlH
1949 F3 Express
  #309
Old 09-23-2014, 11:06 PM
old_dan's Avatar
old_dan old_dan is offline
old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.old_dan has a great reputation on FTE.
CarlH
1949 F3 Express
Carl,
I think the bumpers were optional in that era. I have seen a lot of F1's with a light bumber (stock). The F2's & F3's tended to have a heavy wrap-around diamond plate unit with a mount for a trailer hitch ball. I'm sure some of the big truck guys will weigh in. The stock F1 rear bumpers are hard to find and usually expensive. I made one out of 5 inch channel....I was really looking for a good way to mount a decent set of tail lights....I know...not stock, but sometimes safety outweighs the stock look.
Dan
  #310
Old 09-26-2014, 02:42 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
CarlH
1949 F3 Express
HI Carl,
The bumbers would have been the same if they came with them, there are a lot of aftermarket bumpers that were probably dealer ad on's though.
I knew the tailgate chains were different but never really compared them side by side so I took this picture (sorry about the poor quality it was getting dark out)
Anyway the F-2 3 chains are a little bit longer (about 29") than the f-1 chains and also a lot bigger
F-1 on bottom F-2 3 chain on top
  #311
Old 07-16-2015, 12:43 PM
Installing brightwork mouldings
I am getting to the final stages of restoration and have a question about how to install the bright mouldings to the hood. Does one install the clips first and then slide the moulding over them? Or does one install the clips in the moulding and try to push it on?
I tried sliding...and scratched the paint. Then I tried pushing on, and it bent the moulding.
CarlH
1949 F3 Express
  #312
Old 07-16-2015, 11:33 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The clips go in the moulding, then snap into place on the hood. They can be a bit of a bear, and you may need to help them go through the hole with pliers or other handy tool.
PS, it's OK to start a new thread with your questions. In fact, it's preferable to digging up 2 year old topics and hope someone finds it.
  #313
Old 08-11-2015, 05:11 PM
Color of chains?
Quote:
Originally Posted by jmadsen View Post
HI Carl,
What color were the chains originally?
  #314
Old 08-11-2015, 09:12 PM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
The chains were the same colour as the body .
  #315
Old 08-12-2015, 08:00 AM
Chain connection at stake pocket
Can someone post a picture of the F3 Express chain connection at the top of the stake pocket? How much clearance should be allowed between the tailgate and bedside brackets?
Any chance of saving this 1959 F100 4x4 Custom Cab rust bucket chetspencer 1957 - 1960 F100 & Larger F-Series Trucks 141 05-01-2016 09:48 PM
Vintage Picture Thread. (WARNING: 56K ~ Picture Loadin' Death!) 76f350spercamprspeal 1973 - 1979 F-100 & Larger F-Series Trucks 97 04-03-2016 11:16 PM
New Member- My '51 Project So Far 2" Chop (Pics) Bgrassguitar 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 08-22-2013 04:32 PM
It's Finally Here cnvF250 2009 - 2014 F150 11 04-16-2012 10:10 PM
2010 FTE '57-'96 General Championships-Round-7 76f350spercamprspeal Picture competitions 19 09-12-2010 09:19 AM
Tags
1949, 49, 51, brakes, disc, f3, ford, frame, front, parts, pickup, restored, restoring, specs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
