1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
power for my CB
Old 10-04-2009, 09:11 PM
Macamon's Avatar
Macamon
Macamon is offline
power for my CB
2000 F250 PSD, Auto trans
Where can I hook up 12v (preferably switched accessory)?
Old 10-04-2009, 09:20 PM
420CREW's Avatar
420CREW
420CREW is offline
I ran mine to the fuse panel
Old 10-04-2009, 09:28 PM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
I found a hot-when-on wire under the dash bundled into the conduit with the PCM port. Ran the wire into a power conditioner then into my CB. I don't know why you want a switched power wire?
Old 10-04-2009, 09:32 PM
Macamon's Avatar
Macamon
Macamon is offline
How did you do it? what color wire? where?
Old 10-04-2009, 09:51 PM
texastech_diesel
Token Redneck
I took a volt meter and started poking the blunt cut wires in the bundle over the PCM port, and found one that's only hot when the key is turned on, I think it was blue with a colored chase on it. A friend of mine just ran a wire through the firewall and to the battery, then ran it through a power conditioner, that works too.
Old 10-04-2009, 10:16 PM
twags6's Avatar
twags6
twags6 is offline
The 07's are different then the earlier models. The SD's with the PSD should have 4 customer access wires that run from under the dash, through the firewall, and stop near the master cylinder. You can use those if you want to hook up to the battery. As for a hot in run wire, I'll have to check where I tapped in for my gauges and get back to you.
EDIT: Here's where I tapped in. There are others under there but I'm not sure on colors. http://dieselmanor.com/diy/PSD3-gauge/image35.htm
Old 10-05-2009, 01:51 AM
ford7379trucks's Avatar
ford7379trucks
ford7379trucks is offline
direct to the battery is best.
Old 10-05-2009, 10:54 AM
BiggdaddyF250's Avatar
BiggdaddyF250
BiggdaddyF250 is offline
I tapped mine into the hot-with-key-on wire that goes to the radio and changed the fuse to 30amp. When I turn on the key the CB comes on like the radio and also turns off when the key is off. Or, I can turn it off on the front. No problems yet and it has been in for 1 year.
Old 10-05-2009, 12:19 PM
ehchvac's Avatar
ehchvac
ehchvac is offline
If you are running any kind of power "big radio" you need to run both to the battery.
Old 10-05-2009, 01:54 PM
Sebs's Avatar
Sebs
Sebs is offline
It's never a good idea to put a bigger fuse in without changing the wire size to match the fuse. If you have a short you may burn up the wire before the fuse blows.
Old 10-05-2009, 02:13 PM
texastech_diesel
Token Redneck
I've run my tuned up 30 watt on that wire for over a year now, no problems. But yes, the 350 watt footheater was on its own line to the battery.
Old 10-05-2009, 02:34 PM
Sebs's Avatar
Sebs
Sebs is offline
The point is not whether it will work. In normal use you're obviously drawing less than 30 amps, probably less than 20 amps (in which case you could use a 20 amp fuse). But if you have a short out on the end of a wire that was meant for a 20 amp circuit, what is going to burn out first - the 30 amp fuse or the 20 amp wire? Which would you rather have burn out?
Old 10-05-2009, 02:38 PM
BPofMD's Avatar
BPofMD
BPofMD is online now
Received 1,076 Likes on 978 Posts
...... and possibly cause a BIG FIRE????
Old 10-05-2009, 03:13 PM
Sebs's Avatar
Sebs
Sebs is offline
Texastech - my comment above was meant for replacing the fuse with a bigger fuse. I agree with you, if you didn't change the fuse size, and it doesn't blow, there is no reason not to do it the way you did. But if you need more power than the factory fuse can supply, like your 350 watt amp, then you need to run the appropriate sized wire with fuse to the battery. Sounds like you did it right.
Old 10-05-2009, 07:31 PM
BiggdaddyF250
Like I said, no problems in a year... My CB is not a BIGUN' either. It's a new 1989 model Cobra 146GTL that was still in the original box without being opened in 20 years. I got lucky at a yard sale... All that I have done to it is add a swing kit to it and I DID check the amp draw while I was talking in the CB and had the radio on. It did not even draw 15 amps. I am only saying that it worked for me.
Quick Reply: power for my CB
