Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-04-2009, 09:46 PM
DILLIGAF13's Avatar
DILLIGAF13 DILLIGAF13 is offline
1989 Ford F-350
DILLIGAF13 is starting off with a positive reputation.
Rockwell lift??
How much lift is needed to clear rockwells on 89 f350 extended cab??
  #2 (permalink)
Old 10-04-2009, 09:57 PM
chickenfry123 chickenfry123 is offline
chickenfry123 is starting off with a positive reputation.
you dont need lift to clear the axles you need lift to clear the tires...
  #3 (permalink)
Old 10-04-2009, 10:34 PM
DILLIGAF13's Avatar
1989 Ford F-350
I'm talking about the front axle clearing the crossmember.
  #4 (permalink)
Old 10-05-2009, 05:52 AM
75F350's Avatar
75F350 75F350 is online now
1973 Ford F-100
My Garage
75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all 75F350 is a name known to all
Much depends upon how much you are willing to limit up travel. If you limit the bump, you can clear with about 10 to 12 inches of lift. If you are willing to cut the crossmember, and clearance the pan, you can get away with less lift.
I am assuming that you are using 2.5 ton Rocks with a "top loader" design?
These have a very large input and the top loader design really gets in the way when using them. Great for driveline angles though.
Are you planning on running leafs or a nice link system?
Leafs are difficult to use since they have to take on a banana shape, and do not function too well.
  #5 (permalink)
Old 10-05-2009, 11:04 AM
DILLIGAF13's Avatar
1989 Ford F-350
I'm looking at a top load design on the Rockwells. Initially i want to go with leaf springs and see how that works out and maybe go to links down the road. I live about 5 miles from a large off road/hunting area so I want to be able to drive there but thats the only road use it will see. It'll be like a swamp buggy but with a body and able to drive to the swamp. On a side note 75f350 NICE buildup on the Bronco.
  #6 (permalink)
Old 10-05-2009, 01:08 PM
Prozon's Avatar
Prozon Prozon is online now
1988 Ford F-350
Prozon is gaining momentum as a positive member of FTE.
Dilligaf13, just curious.. what are you putting the rockwells in? That '89 F-350 or something else?
__________________
1988 Ford F-350 460ci EFI
37" Super Swampers - Warn Winch
  #7 (permalink)
Old 10-05-2009, 03:46 PM
hav24wheel's Avatar
hav24wheel hav24wheel is online now
hav24wheel is gaining momentum as a positive member of FTE.
I'll take that D60 out of the front of that 85 if u want to get rid of it cheap. I could put it in my Van. Lol.
__________________
my supermotors page http://www.supermotors.net/users/hav24wheel
78,85,92 Ford
Just bought a 94 F-150
  #8 (permalink)
Old 10-05-2009, 08:45 PM
DILLIGAF13's Avatar
1989 Ford F-350
If I go with the Rockwells they will be going in the 89 F350 and the Dana 60 will be going to the 96 F250 Crewcab I just picked up.
  #9 (permalink)
Old 10-05-2009, 09:46 PM
TheTinian's Avatar
TheTinian TheTinian is offline
TheTinian is gaining momentum as a positive member of FTE.
how big of tires are you palling on running? Why not just build up the 1-tons?
__________________
99 F150 Under the knife again. SAS, 1tons with 17.5 "'s of lift with 44's.
77 F250 For Sale
2001 F250 7.3 lariat 4x4.
  #10 (permalink)
Old 10-05-2009, 10:25 PM
DILLIGAF13's Avatar
1989 Ford F-350
If i do the rockwells i'll go with either 54" boggers or 53" michelins. Need to do some research and compare the two tires performance.
  #11 (permalink)
Old 10-06-2009, 12:58 AM
Prozon's Avatar
1988 Ford F-350
Quote:
Shut up. Enough with the van.
__________________
  #12 (permalink)
Old 10-06-2009, 04:22 AM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is offline
78_f800crewcab4x4 is gaining momentum as a positive member of FTE. 78_f800crewcab4x4 is gaining momentum as a positive member of FTE.
i had to lift mine about 24'' total to clear the rockwell 5 ton under the engine with enough clearance for a good amount of uptravel. not that this is the same sort of thing, but if you are using 54's, you just need to worry about tire clearance.
my leaves only have 6" of lift, so i still have a good ride. my lift has lots of frame modification so that i could run relatively flat springs, and no blocks.
__________________
1978 F600 Bronco 4 door "Centurion"
1958 F700 next "Centurion" project
1973 F350 Crew Cab Special, 460 all race
2002 Excursion Limited 4x4 7.3
Please help them:
http://www.lionconservation.org/index.html
  #13 (permalink)
Old 10-07-2009, 02:10 AM
Prozon's Avatar
1988 Ford F-350
That bronco is huge daamnn.. I can honestly say thats the first four door bronco I have ever seen lol.
As for the tires.. well i'm all for the boggers.. better tire IMO. But then again, i've never run a tire that large myself.
__________________
  #14 (permalink)
Old 11-03-2009, 09:49 PM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
1973 Ford F-100
My Garage
Kirbys73F100 is starting off with a positive reputation.
I picked up a set of four 53 inch Michelins for $400 total. I think a 54 inch bogger runs for over $800 a piece... The Michelins have a J load range and 16 ply (the military runs these on 5 ton 8x8's) meaning they will virtually never wear out. They'll probably dry rot before your F350 wears the tread out. If you run a 54 bogger on the road over about 55 mph for a long enough time, they'll most likely start throwing rubber chunks from over heating. Argument though is which performs better.. Well I don't it gets much better than a bogger and boggers look better than the skinny Michelins but the price of Michelins is no contest.
__________________
1964 F100 429 C6 (drag project)
1973 F100,built 351w C6, Cragars, 4.11 gears, Detroit Locker, QTP electric cut-outs
1979 F250 4x4 460 C6, 44" Gumbo Monster Mudders (will have 2.5 tons and 53's)
1984 F150 4x4 300 big six, Granny 4 speed, locked rear, 6" Rancho, 3" body, 44" Gumbo Monster Mudders
2000 Ranger XLT, 2.5, 5 speed, 2wd (gas saver)
  #15 (permalink)
Old 11-04-2009, 12:50 AM
Prozon's Avatar
1988 Ford F-350
Well when I was on SummitRacing pulling up my 42's I ran a price check on 54" boggers and they were about 850 each.
Just curious Kirby, were those NEW Michelins or used?
__________________
Tags
0n , 25 , f250 , ford , lift , ranger , rockwell , rockwells , rockwills , ton , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
