Stock thermostat housing on 2002 5.4L V8... - Ford Truck Enthusiasts Forums
Old 10-04-2009, 06:44 PM
illinibone2003 illinibone2003 is offline
illinibone2003 is starting off with a positive reputation.
Hey all -
I need to replace the thermostat in my truck - 2002 F150, 5.4L, FX4, about 120K miles. Now, I've done everything up to and including removing the power steering reservoir mounting bolt and the two thermostat housing mounting bolts.
Now, the book says that the housing should just "lift off". However, the thermostat housing is firmly stuck to the mounting surface and won't budge. I've tried tapping it with a hammer and block of wood, prying it up by tapping a putty knife under the edge, pulling, yanking, and cursing at it, and it won't move.
Has anyone come across this problem before? I don't want to beat on it too much because I don't want to damage it, and I can't heat it because there's too much in proximity to the housing.
Any ideas? Thanks all!
**Sorry, I meant "stuck" thermostat housing in the subject.
Old 10-05-2009, 09:35 AM
redwood's Avatar
redwood redwood is offline
redwood is gaining momentum as a positive member of FTE.
The housing doesn't just sit on the manifold, it sets IN it too. Below the mounting surface, the housing extends down into the hole, and seals against the gasket and then the thermostat. This might not be the "right" thing to do, but I'd spray a little penetrating oil around it and let it set, and then tap it with a dead blow or rubber hammer.
When you get it off, the gasket (at least on mine) sits on top of the thermostat, and may be stuck to the housing, so make sure not to forget to remove the old gasket......
Old 10-05-2009, 09:56 PM
All done - thanks for the advice, redwood. What ended up working was taking a drift pin and tapping on the bolt "ears" left and right several times each, to rotate the housing back and forth. Along with some Liquid Wrench, it eventually loosened up and came out - looks like it was just built-up corrosion that had locked it in place.
Thanks again!
Water pump and thermostat housing. jeffreyt 1999 - 2003 7.3L Power Stroke Diesel 10 11-11-2012 08:45 AM
thermostat housing bolts & galvanic corrosion cadjak 1968-2013 Full Size Vans 3 02-28-2010 02:04 AM
thermostat bolts both broke in 93 3.0l... DCRB Aerostar 56 10-28-2009 02:37 AM
2003 F150 4.6L - Blown Head Gasket? ThePerfectCore 2004 - 2008 F150 1 12-06-2008 05:22 PM
Thermostat won't come out!! papadelogan 1999 - 2003 7.3L Power Stroke Diesel 31 04-23-2008 06:39 AM
Tags
2000, 2001, 2003, 54l, f150, ford, housing, recalls, removal, replace, replacing, thermastat, thermostat, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
