oil filter wrench
Old 10-04-2009, 03:49 PM
hdman6's Avatar
hdman6
hdman6 is offline
Question oil filter wrench
I just finished changing my oil and filter. For the last 4 years I had a service book I bought at the time of sale for this. I had a heck of a time getting the oil filter off. I ended up driving a large screwdriver through it several times to crank it, then it finally broke loose. So since my small strap wrench isnt enough what do you guys use? I will invest in the right one if I can find it. It seems I will need a pretty good size one to get it off. thanks Jeff
Old 10-04-2009, 04:14 PM
Visseroth's Avatar
Visseroth
Visseroth is offline
You can get a oil filter attachment for a ratchet. I don't have one though I usually don't need one but they are handy. Usually I can take it off with my hands and sometimes a paper towel to get a better grip and if it's real tough I wrap my belt around it a couple times and use my belt as leverage.
Old 10-04-2009, 04:18 PM
fifthwheel01's Avatar
fifthwheel01
fifthwheel01 is offline
hi,Jeff I use a strap wrench from Sears. It's about 10"long handle w a long rubber strap. They came two to a pkg for $15. Called a multi something or other. I also had a hard time on the first filter. But no problem anymore, I make sure I clean the contact surfaces real good then oil the gasket like hell . Oh and don't over tighten! Do you have a fumoto? If not get one you'll love it.
Old 10-04-2009, 04:32 PM
HKusp's Avatar
HKusp
HKusp is offline
This is the one I got. I got it from a local autoparts chain here called Salvo. It measures 4 and 3/4 inches when open and 4 and 1/4 inches when "closed". It also has the ability to fold the handle 90 degreees.
Old 10-04-2009, 04:36 PM
maevans's Avatar
maevans
maevans is offline
This is the one I use thanks to Dan (Kwik) https://www.ford-trucks.com/forums/4...oval-tool.html
Old 10-04-2009, 04:41 PM
big poppa's Avatar
big poppa
big poppa is offline
Got the same one as Jason's, local parts store Pep-boys..
Old 10-04-2009, 05:04 PM
Bigcat350's Avatar
Bigcat350
Bigcat350 is offline
NAPA has a nice one for our filters also IIRC it was about $15 and its # is 77-2320
Old 10-04-2009, 05:09 PM
orng1's Avatar
orng1
orng1 is offline
I use one like HKusp has. Haven't had any trouble except the first time I changed the oil when I bought it. It was cranked down tight.
Old 10-04-2009, 06:54 PM
blue1ton's Avatar
blue1ton
blue1ton is offline
Another vote for the oil filter wrench like HKusp has. I have one just like it, works great never had an issue with removing our oil filter.
Old 10-04-2009, 07:10 PM
swaybar's Avatar
swaybar
swaybar is offline
i've dealt with this same situation awhile back, i always had a tuff time getting the filter off cause i always put it on so tight, worrying about a leak, so on my "second" to last oil change i only tightend the filter as tight as i could get it with my hands. i watched it religously for a few days and it never leaked.
ten months go by, and it was time to change the oil again "which was just two weeks ago" and i got under the truck and had just remembered it was only hand tightend. i had to put alot of muscle into it but it came right off by hand. did the oil change and only hand tightend it again.
love it!!
Old 10-04-2009, 07:39 PM
bunklash's Avatar
bunklash
bunklash is offline
I own 2 or 3 filter wrenches, but never need it for my own vehicles. I oil the gasket, spin the filter on 'till it stops with light pressure, then 1/2 to 3/4 more turn. Never leaks or comes loose, but removes with only a rag for grip. Filters with the rough black paint for grip is a bonus.
Old 10-04-2009, 08:29 PM
HKusp's Avatar
HKusp
HKusp is offline
Those filters with the grip are usually Fram brand and they are junk. Stop using them.
Old 10-04-2009, 08:35 PM
bunklash's Avatar
bunklash
bunklash is offline
I hear ya on the Fram. I only use Motorcraft 1995's on my PSD, couldn't remember who made the gripper ones. Too bad others don't use it, it works!
I've got a can of spray undercoating gathering dust. I wonder if it would serve the same purpose? Maybe if I remember next change, I'll give it a try.
Old 10-05-2009, 12:02 AM
Visseroth's Avatar
Visseroth
Motorcraft FTW!!! That's all I've ever heard, Powerstroke = Motorcraft = Decent materials, well, most the time :-P
Old 10-05-2009, 12:59 AM
mechelement's Avatar
mechelement
mechelement is offline
That's the one I use. The first time I changed the oil, I had to use that with an extension and a 1/2" drive breaker bar. That was after smacking a hole in the bottom of the filter. The previous owner had the truck maintained at a Jiffy Lube type place. Those turds must've installed the damn filter with an impact gun.
Quick Reply: oil filter wrench
