1986 f-250 6.9 diesel Wiring issues. NEED diagram. - Ford Truck Enthusiasts Forums
Old 10-04-2009, 03:25 PM
shanes66charger shanes66charger is offline
shanes66charger is starting off with a positive reputation.
Hey guys.
I just bought a 1986 F-250 4x4 4-speed with a 6.9 diesel. Truck runs great etc. There is only one battery in it and it has a new alternator. We noticed once we got it home that the wiring around the solenoid and regulator is all melted and burned up. We don't know what happened to it but its toasted.
Wondering if anyone here has a diagram of the wiring they could post??
Also, is there any way to TEST the glow plugs also?
any help is appreciated!
thanks!
Old 10-04-2009, 03:52 PM
84 f250 6.9's Avatar
84 f250 6.9 84 f250 6.9 is offline
84 f250 6.9 is starting off with a positive reputation.
there is supposed to be 2 batteries one on the drivers side and one on the passenger side. and I suck with wiring so thats all i have to say haha
Old 10-04-2009, 09:02 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Here's a diagram of the engine wiring. I don't believe it shows all the wiring on solenoid on the fender(power relay), but usually in the diesel trucks the solenoid is just a junction for power distribution. You willl notice the large battery wiring goes directly to the starter, and that is the power priority. They will have a smaller wire coming off the battery feeding the solenoid. The keyswitch activates the solenoid in "start", and in turn sends a signal down to the starter solenoid mounted to the starter.
All the other connections on the solenoid are on the same terminal as the bat + is connected, and this a power distribution point for the glowplug system, the power for the cab, the spot were the alternator is hooked up, etc.
Old 10-04-2009, 10:22 PM
hey thanks a ton man, This SHOULD be enough to at least get us started.
Thanks again!
Old 07-23-2011, 08:00 PM
vfelix702's Avatar
vfelix702 vfelix702 is offline
vfelix702 is gaining momentum as a positive member of FTE.
look on top of your GP controller looks like the wire might head that way according to the picture if you find it then use your meter and disconnect that wire on top of the gp relay and ohm it out if continuity is present then its the right wire and looks like yur gp relay is bad
Old 07-11-2014, 01:32 PM
mstreman mstreman is offline
mstreman is starting off with a positive reputation.
I have an 86 F350 6.9 with starting issues. While tracing wires I found a tubular, 2 contact, female connector which comes off the harness very close to the alternator. I've searched for an hour and cannot find any male connectors to plug it into. Before I try to upload a photo does anyone know off hand what this should go into?
Old 07-11-2014, 09:08 PM
ifrythings's Avatar
ifrythings ifrythings is offline
ifrythings is gaining momentum as a positive member of FTE.
That would be the connection for the tach sensor
Old 07-11-2014, 10:50 PM
Quote:
Great! and thanks, I am looking that up-- timing gear cover--- Now if I can find it on the truck. Thanks for the assist.
Old 07-12-2014, 01:25 AM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Right there, front and center. It's the cover with the oil-fill in it!
Old 07-12-2014, 05:13 AM
Ah so..mine is missing and has a pipe plug.
Old 07-12-2014, 04:01 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Is your tach the factory one? If not, and if it's not an automatic, there won't be a tach sensor. My '85 T19 XL has no tach, and a plug in the sensor port. There is no crank or cam sensor.
Old 07-13-2014, 12:44 AM
My Bad -- I was thinking of the wrong truck--I have several and mentally commingled them. This one had no tach.
Old 07-13-2014, 11:50 AM
So the tach sensor isn't "missing", it was never there.
So what's your starting issue?
Old 07-13-2014, 12:04 PM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
Quote:
I guess the tach is part of an option package. My '85 XLT Lariat was factory T19 and it has a tach.
Old 07-13-2014, 05:47 PM
I got it started ,finally! I think over the three years sitting all the fuel flowed back into the tank and left Air where there should have been fuel. Got it started and had 5 leaking return fuel cups . Replaced all 16 o-rings. ( Got them at Tractor Supply for 1.99 for 8) These are hydraulic applications so hope they will last. Everyone of the o-rings had lost elasticity. No leaks
The remaining problem is that when I switch to the front tank the fuel level meter goes to zero and within a few seconds the engine starts missing. I will finish up the o-ring installation tonight and start on blowing out lines to the tank and see if that is the problem. >>>>>>>>>Carried to a new thread<<<<<<
1986 F350 with Diesel vathicus 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 10-17-2016 09:47 AM
transmission switch on 1986 6.9 freefisherman Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 04-27-2015 06:27 PM
86 f250, 6.9 fuse block diagram krookedford 1987 - 1996 F150 & Larger F-Series Trucks 0 10-24-2011 11:56 PM
1986 F250 6.9L Wiring Schematics/Diagram timb1776 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 06-04-2011 09:17 AM
engine wiring diagram for 1986 F350 6.9L diesel rickgthf 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-13-2006 10:15 PM
Tags
1983, 1984, 1986, 4x4, 69, 69l, altenator, diagram, diagrams, diesel, digram, f250, ford, maintenance, moter, truck, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
