The Mazda 5 speed would have OK ratios for this application, but probably wouldn't last long. The ZF would probably take the power, but really, you want a granny first gear trans in a sport truck?
Go find one to drive and sample the ratio spread and shift quality before you saddle yourself with one.
A granny gear isn't neccessary in a single cab/short bed 2wd truck with a 351 and 4.10 gears.
__________________
Matt C.
Intercooled Vortech, Victor Jr. heads, roller cam, ARP hardware, Canton main girdle, FMS Mass Air and tuned with SCT software.
I agree. A manual would be more fun but your options leave much to be desired.
Quote:
Originally Posted by 96 ford f150
does any body know what gear i have in my rear end ive heard i had 4.11 rear end but im not sure it is stock and i think it is a 2.73 which is it
Your year Ford F-150 came from the factory with either a 3.08 or 3.55 gear ratio. Look at the paper sticker tag on the inside of your door and read us the axle code. Or, crawl underneath your truck and look for a metal tag on a bolt on your differential cover.
