runs rough - Ford Truck Enthusiasts Forums
runs rough
Old 10-04-2009, 08:05 AM
pkenn7 pkenn7 is offline
pkenn7 is starting off with a positive reputation.
runs rough
I have an 02 v10 that has started running rough intermittantly. sometimes while im driving, sometimes when i first start it. it happens for a while then goes away. it feels just like when a distributor goes, or you have a bad plug.......any ideas? just changed my plugs a few months ago.
Old 10-04-2009, 08:54 AM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
Do you have a CEL?, could be a COP or two. If the CEL is on it's a good chance it's a miss and the code will direct you to which cylinder to check and replace that COP.
Old 10-04-2009, 01:01 PM
i plugged in my tuner, and got code p1000 which is something like it needs to be driven more.....but its been going on for a couple of weeks so far.
Old 10-04-2009, 01:28 PM
P1000 basically means the truck has not been driven enough since last reset,
Ford Motor Company Driving Cycle
Description of OBDII Drive Cycle
The following procedure is designed to execute and complete the OBDII monitors and to clear the Ford P1000, I/M readiness code. To complete a specific monitor for repair verification, follow steps 1 through 4, then continue with the step described by the appropriate monitor found under the "OBDII Monitor Exercised" column. When the ambient air temperature is outside 4.4 to 37.8C (40 to 100 F), or the altitude is above 2438 meters (8000 feet), the EVAP monitor will not run. If the P1000 code must be cleared in these conditions, the PCM must detect them once (twice on some applications) before the EVAP monitor can be "bypassed" and the P1000 cleared. The Evap "bypassing" procedure is described in the following drive cycle.
The OBDII Drive Cycle will be performed using a scan tool. Consult the instruction manual for each described function. NOTE: A detailed description of a Powertrain Control Module (PCM) Reset is found in this section, refer to the table of contents.
Drive Cycle Recommendations:
* Most OBDII monitors will complete more readily using a "steady foot" driving style during cruise or acceleration modes. Operating the throttle in a "smooth" fashion will minimize the time required for monitor completion.
* Fuel tank level should be between 1/2 and 3/4 fill with 3/4 fill being the most desirable.
* The Evaporative Monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize "fuel slosh".
WARNING
STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
For best results, follow each of the following steps as accurately as possible:
OBDII Monitor
Exercised
Drive Cycle Procedure
Purpose of
Drive Cycle
Preparation 1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset. Bypasses engine soak timer. Resets OBDII Monitor status.
2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.
Start vehicle WITHOUT returning to Key Off.
3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7C (170 F).
Prep for Monitor Entry 4. Is IAT within 4.4 to 37.8C (40 to 100 F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000. Engine warm-up and provide IAT input to the PCM.
HEGO 5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes. Executes the HEGO monitor.
EVAP 6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85% Executes the EVAP Monitor (If IAT is within 4.4 to 37.8 (40 to 100F))
Catalyst 7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period. Executes the Catalyst Monitor.
EGR 8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times. Executes the EGR Monitor.
SEC AIR/CCM (Engine) 9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes. Executes the ISC portion of the CCM.
CCM (Trans) 10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times. Executes the transmission portion of the CCM.
Misfire & Fuel Monitors 11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times. Allows learning for the misfire monitor.
Readiness Check 12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13. Determines if any monitor has not completed.
Pending Code Check and Evap Monitor "Bypass" Check 13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8 C (40 to 100 F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.
Proceed to step 14. Determines if a pending code is preventing the clearing of P1000.
Evap Monitor "Bypass" 14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1. Allow the "bypass" counter to increment to two.
Old 10-04-2009, 04:25 PM
thanks, i did that and got code po310-cylinder#10 misfire, and code p0316?- which isnt in my book..................
Old 10-04-2009, 05:29 PM
I think P0316 is a misfire detected in first few minutes or 1000 revolutions, I would start by changing coil #10 since you already did the plugs and go from there.
Old 10-05-2009, 05:39 PM
thanks for all your help. new plug and coil toaday. col was $100!! wow
Old 10-05-2009, 05:40 PM
Quote:
All better now?
Old 10-05-2009, 05:55 PM
yes, all better...thank you!!
Old 10-05-2009, 06:10 PM
No problem, thanks for reporting back.
runs rough at idle intermently and smokes lost???? 7.3 junkie 1999 - 2003 7.3L Power Stroke Diesel 6 01-15-2013 09:49 PM
Rough idle Sometimes???????? Mike8623 1994.5 - 1997 7.3L Power Stroke Diesel 7 08-02-2011 12:52 PM
Seems like it's one thing after another... AndeyHall 6.0L Power Stroke Diesel 49 11-11-2010 10:21 PM
95 Bronco rough idle/rough acceleration Broncobudy 1978 - 1996 Big Bronco 36 09-24-2010 02:41 PM
STUMPED!! 97 4.2 misfire. rough idle and stall mlb5000 1997 - 2003 F150 1 08-18-2010 09:35 PM
Tags
40, 50, checks, code, excursion, ford, hour, ii, incomplete, miles, obd, p1000, rough, running, runs, system, troubleshooting, truck, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
