Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Bio-diesel, Propane and Alternative Diesel Engine Fuels SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-03-2009, 12:53 PM
Rushmore X Rushmore X is offline
Rushmore X is starting off with a positive reputation.
What do you guys use for Reactor pumps?
The pump the I use is a Clearwater that I got off Ebay for $19.99. I have a questions related to the pump.
For methanol recovery, I heat up the processor to about 175 and let it run a few hours until the drip rate slows. Usually end up recovering about a gallon off of the bio. (35 gallon batches). The bio still smells fairly strong of methanol, so I need to get more out. (and use less Magnesol) However, if I heat beyond 175, the pump starts to drip. I think the seals can't handle it. I've run about a dozen batches so far.
I've read that I should be heating to 90C, or around 200 degrees. I heard Harbor Freight pumps are recommended, would it handle the heat better?
thanks,
Trent
__________________
2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, more to follow! Gone BIO!!!
  #2 (permalink)
Old 10-03-2009, 01:22 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
Biodiesel Guru
fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold fabmandelux is a splendid one to behold
Sorry Trent, can't help ya much on this question. I use mechanical mixing, and use an air powered chemical pump for everything else.
__________________
Don.
Oregon Chapter Leader: To join the Oregon Chapter, click HERE
  #3 (permalink)
Old 10-03-2009, 02:02 PM
Hi Don,
How hot do you run your distillation? Just trying to get as much out as I can. thanks again
__________________
  #4 (permalink)
Old 10-03-2009, 02:07 PM
Biodiesel Guru
I'm using an experimental system I'm developing that requires far less heat, but when I was heating it I started getting Methanol about 160-170, but it really started flowing above 180-190.
__________________
Don.
  #5 (permalink)
Old 10-03-2009, 04:13 PM
thanks, that's what I thought - need to crank her up a little bit...
Constant process reactor????
__________________
  #6 (permalink)
Old 10-03-2009, 10:02 PM
binuya's Avatar
binuya binuya is online now
binuya is gaining momentum as a positive member of FTE.
[quote=Rushmore X;7995573]The pump the I use is a Clearwater that I got off Ebay for $19.99. I have a questions related to the pump.
thanks,
I've been running the cheap HF blue pump for the past year and a half, and it's still running strong. Each batch is heated to 140f, and it usually runs for 2-4 hours total.
Not sure you would have much better luck with these. While mine doesn't drip, it does weep enough to have to wipe around the pump.
__________________
Alvin
2001 F250 CC SB 4x4 Lariat
6637, MBRP 4" Turbo Back, HPX, AIH Delete,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard
Homebrew American Biodiesel (B100 whenever I can)
  #7 (permalink)
Old 10-03-2009, 11:19 PM
Do you distill methanol off your bio?
__________________
  #8 (permalink)
Old 10-03-2009, 11:44 PM
binuya's Avatar
Quote:
No, I don't. I'm not yet convinced I want to go that route. I get decent wvo, and with glycerin pre treat, I go 18%-19% methanol single stage. For me it's about whether or not the added equipment and time is worthwhile.
__________________
Alvin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
