Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-03-2009, 09:56 AM
664x4drvr 664x4drvr is offline
1994 Ford F-150
664x4drvr is starting off with a positive reputation.
1966 f100 power steering wheels go oppisite way???
We mounted a 1978 or so power steering box on my 66 when steering wheel is turned it goes the wrong way. we took pitman arm off of bottom of box and rotated it 180 degrees (on bottom of box) it makes sense don't know how to fix any ideas?
  #2 (permalink)
Old 10-03-2009, 10:32 AM
Bill W's Avatar
Bill W Bill W is offline
<<< under construction
1966 Ford F-100
My Garage
Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of Bill W has much to be proud of
Are you sure the Power steering fulid hoses are hooked up right?
__________________
My Truck- Here!
Join AZ Chapter Here!
  #3 (permalink)
Old 10-03-2009, 12:03 PM
jowilker's Avatar
jowilker jowilker is online now
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
Post the number off of it, Bill da dummy can tell for sure, but it sounds to me like you have a 80 or newer in front of the axle gear rather than a behind the axle 79 down.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #4 (permalink)
Old 10-03-2009, 10:13 PM
jared66's Avatar
jared66 jared66 is offline
jared66 is starting off with a positive reputation.
Did it come off a ford? I think the international steering boxes will bolt up , but are opposite like what your saying.
  #5 (permalink)
Old 10-03-2009, 10:15 PM
1994 Ford F-150
Thanks, Mr. jowilker and Billw for replying. The numbers are; on the side of the box, RFD6TW3550AA. Top of box on a tag, SPA76B20. A number where the slack is adjusted is; C6AR3580-A2 What i seem to need is a steering box with has the pitman pointing to the rear. The one I have supposed to be a 1978-79 was pointing to the front. I used my old pitman rod, rotated it to the rear Thanks.
  #6 (permalink)
Old 10-03-2009, 11:11 PM
1994 Ford F-150
This box came from a friend, it is a ford. I read some where the box needed to be reworked to function on a older model?????
  #7 (permalink)
Old 10-04-2009, 03:38 AM
65fordguy's Avatar
65fordguy 65fordguy is offline
65fordguy is starting off with a positive reputation.
Dunno about all that, I got mine off of a mid 70s ford and it functions correctly.... or im backwards one. lol. I know of many guys who used these and never had that happen... it seems I do remember someone telling me that the larger trucks like f500 s or whatever used a different box..... either way.. something isnt right...
  #8 (permalink)
Old 10-04-2009, 05:55 AM
jowilker's Avatar
1966 Ford F-100
We'll have to wait on Bill or Don, dummy 2 to chime in for your number decode.
You must have been reading a magazine article about the reworking deal. We get some of those writers stop by here on their way to the top.
John
__________________
  #9 (permalink)
Old 10-04-2009, 06:08 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by 664x4drvr View Post
The numbers are; on the side of the box, RFD6TW3550AA. Top of box on a tag, SPA76B20. A number where the slack is adjusted is; C6AR3580-A2.
RFD6TW3550AA is the ID number for steering gearbox housing only / This housing was used on Bronco's & F100/350's, so this ID number is no help.
C6AR3580A2 is the ID number for the sector shaft cover only / This part was used on cars, trucks, Bronco's, some Econolines, so this ID number is no help either.
This is what's needed: SPA76B20. 76B20 = You copied it down wrong.
SPA is a Ford P/S gearbox from a 1973/79 F100/350 2WD, or 1976/79 F100/250 4WD, or 1979 F350 4WD.
However, the correct suffix pins it down to certain years, 2WD or 4WD.
The number should read like this assuming that the B is correct: SPA-AB, or: -CB, -BN, -BS, -BX, -BY.
You sent me a Visitors Message asking for assistance. I suggested you contact FTE member 75F350, as this fellow is an expert on 4WD P/S conversions.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #10 (permalink)
Old 10-04-2009, 12:57 PM
carras carras is offline
carras is starting off with a positive reputation.
could the gearbox have been turned beyond the stop while it was off so that it is now 180 degrees off? I don't know if this is possible, though.
  #11 (permalink)
Old 10-04-2009, 01:08 PM
jowilker's Avatar
1966 Ford F-100
Quote:
Can not.
John
__________________
  #12 (permalink)
Old 10-04-2009, 03:35 PM
banjopicker66's Avatar
banjopicker66 banjopicker66 is online now
In Occupied CSA
banjopicker66 is gaining momentum as a positive member of FTE. banjopicker66 is gaining momentum as a positive member of FTE.
Is your '66 a 4x4 or A 4X2?
It appears to me you have installed a 4x2 '70s power steering gearbox on a '66 4x4.
These are not interchangeable.
__________________
1966 F-100 460, C6, power disc brakes, power steering
2000 F-250 SuperDuty 7.3L Diesel 150K, pillar gauges, oil drain valve - Infected with PMS.
He is no fool who gives up what he cannot keep to gain what he cannot lose! (cf Mt 16: 25, 26)
Deo Vindice!
  #13 (permalink)
Old 10-05-2009, 01:14 PM
bertha66's Avatar
bertha66 bertha66 is offline
1966 Ford F-100
bertha66 is starting off with a positive reputation.
Banjopicker66 is right, if your truck is a 4x4, you can not use a 2wd box. Myself. I used a P/S box off a 4x4 Toyota on my 66 4x4. It was cheaper and a EZ change over. But that IMHO.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1964 Galaxie 500 with 428
Oregon Chapter Member: To join the Oregon Chapter, click HERE
  #14 (permalink)
Old 10-05-2009, 09:49 PM
1994 Ford F-150
This is a 4 wheel drive f100 1966
  #15 (permalink)
Old 10-05-2009, 09:52 PM
1994 Ford F-150
QUESTION: Is threr more than one late 70's power steering box? pit man out the front and pitman out the rear?
Tags
1964 , 1966 , 62 , 64 , 66 , 78 , engine , f100 , ford , power , steering , truck , trucks , wheel , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
