Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1961 - 1966 F-100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1961 - 1966 F-100 And Larger F-Series Trucks Discuss the Slick Sixties Ford Truck SPONSORED BY:
Is F-150 Still King?
  #16 (permalink)
Old 10-06-2009, 01:47 AM
jhooch's Avatar
jhooch jhooch is offline
jhooch is starting off with a positive reputation.
You can use 80-96 internals in a 78-79 F150/Bronco 4X4 steering gear to make it turn the opposite way.
__________________
Jhooch
'05 Excursion LTD 4X4 6.0, '01 F250 4X4 Crew 7.3
'73 Bronco 302 C4, '76 F250 4X4 Crew 360, 4-sp
'66 F100 4X2 LB Custom Cab 428, C6
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'63-64 Ford Galaxie's, 55 Ford Customline 2-dr
  #17 (permalink)
Old 10-06-2009, 06:12 AM
jowilker's Avatar
jowilker jowilker is offline
1966 Ford F-100
jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE. jowilker has a great reputation on FTE.
jhooch, You are correct, you jogged my memory, and I found an old photo of the gear top part.
The input shaft in the top of the gear uses large balls (about 25) to turn the gear below. The top (where the lines connect) uses spiral twisted in like a right twist and the 80 & newer uses opposite.
I believe the OP can find a 80 or newer gear swap the top part and now have the correct turning gear shaft.
Be careful when removing, 25 must have balls are a lot to go chasing if they get away.
John
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #18 (permalink)
Old 10-06-2009, 11:30 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation NumberDummy has a superb reputation
Quote:
Originally Posted by 664x4drvr View Post
QUESTION: Is threr more than one late 70's power steering box? pitman out the front and pitman out the rear?
No.
It is possible to install 2WD gearbox in these 4WD trucks, but it's not a simple installation. You need welding skills, and have to modify the frame.
1966 F100 4WD's are very similar in design to 1967/77 F250 4WD's aka High Boys. No other 1966 or earlier 4WD truck is the same.
I've suggested...at least twice before ...that you contact FTE member 75F350 because he is the one that knows how this can be done.
__________________
Bill / Retired Ford Partsman (1962/97) / SoCal Chapter Member.
Part Number Research: Trucks: 1928/2000 // Cars: 1928/79.
1934 Packard V12 Convertible Victoria // 2008 Fusion S // 2008 Edge SEL.
  #19 (permalink)
Old 10-06-2009, 11:12 PM
664x4drvr 664x4drvr is offline
1994 Ford F-150
664x4drvr is starting off with a positive reputation.
664x4drvr power steering
Thanks guys for your input, I have been in touch with 75F350. Advance auto claims to have a 66 4x4 powr box will be here wed. am i'm curious to see . As I understand F100s got full power after 1976
  #20 (permalink)
Old 10-06-2009, 11:21 PM
1994 Ford F-150
Quote:
Originally Posted by bertha66 View Post
Banjopicker66 is right, if your truck is a 4x4, you can not use a 2wd box. Myself. I used a P/S box off a 4x4 Toyota on my 66 4x4. It was cheaper and a EZ change over. But that IMHO.
Would it be possible for you to post some pictures of your box?
  #21 (permalink)
Old 10-07-2009, 05:09 PM
bertha66's Avatar
bertha66 bertha66 is online now
1966 Ford F-100
bertha66 is starting off with a positive reputation.
I'm sorry I do not, I do not have a digital camara, and the film pictures that I had were sent to a member here awhile back. But it looks close to the OEM box and sits in the same place. PM me if you would like a write up of how I put it on the truck.
__________________
Allen D
1966 F-100 4x4 with 390 GT engine
1990 Areostar 2wd XLT ext
1980 Bronco with 460
1964 Galaxie 500 with 428
Oregon Chapter Member: To join the Oregon Chapter, click HERE
  #22 (permalink)
Old 10-07-2009, 09:36 PM
1994 Ford F-150
66 4x power steer
Could you provide me with exact description and year of pieces used.
what year toy box , any other other than stock items you used. I have a hard time with getting pictures on here. Thanks, 664x4drvr
  #23 (permalink)
Old 10-08-2009, 12:19 PM
bertha66's Avatar
1966 Ford F-100
I used a box out of a 87 Toyota 4x4. When I got the box, I also took the P/S lines that run from the pump to the box.
I removed the driver side fender and inter fender for better access.
1. Remove the old steering box and the steering link that runs from the box to the drag link.
2. Place the new box in the same place as the old one. mark the holes that need to be drilled, drill and tap into the frame, or drill all the way and put in a bolt and nut.
3. The new box, the pitman arm has a stud, where as the old pitman arm has a hole to hook the box to the drag link. I used a piece of a drag link that came from a Chevy truck that had a hole in it, the hole has to fit the stud on the pitman arm. The steering link that came off, I cut that in half and treaded the the Ford piece and the Chev piece togather using left and right treads and a turnbuckel off a tie rod end, got from the tie rod end off the Chev. Thet way the length is ajustable. Sence I had the drag link off that links the wheels togather on my truck, I cut off the nonreplaceable tie rod end and treaded a new new and turnbuckel. Now I don't have to replace the whole thing when the end goes bad again. You do not have to do that for this conversion.
4. I used a P/S pump off a 75 F100 Ford truck. The P/S lines that came from the Toyota, you will need to cut the pressure line fitting off at the pump end and replace it with a SAE fitting that fits the Ford pump.
I mounted the cooling loop with the horn on the drivers side.
5. I had to cut the steering shaft @ 3" and welded the end back on. Have someone that is a GOOD welder do this. The input shaft on the Toyota is smaller, so when you put in coupler on, I cut the slit on the clamp that holds the steering shaft to the coupling and tighten the clamp down.
6. I used a pully off a 64 Galaxie, I just had one, but when you pull a pump off at the wrecking yard get the P/S pully off the crankshaft.
Let me know if you need anything else.
Allen Dendy e-mail is abertha2@juno.com
__________________
Allen D
  #24 (permalink)
Old 10-14-2009, 06:31 AM
1994 Ford F-150
UPDATE, since I already had the 76-79 4x4 power st box I did a worm gear swap, check it out at; westcoastbronco.com/tech/diyrockcrawler.shtml Gotta get my truck back together but at least the wheels turn the right direction. THANKS-----
  #25 (permalink)
Old 10-16-2009, 10:02 PM
1994 Ford F-150
Problem solved-
  #26 (permalink)
Old 10-23-2009, 03:18 PM
almustang almustang is offline
almustang is starting off with a positive reputation.
1/2 ton 4-4 box arm goes to front. box fits back on frame, farther then you would think
almustang
  #27 (permalink)
Old 10-26-2009, 09:17 PM
bigbeerbb bigbeerbb is offline
bigbeerbb is starting off with a positive reputation.
HI, How much modification was needed to mount the 76-79 gear to the frame?
I would really like to keep my truck stock looking, thanks
  #28 (permalink)
Old 10-27-2009, 12:24 PM
p/s
I has been awhile sense I did last one. Mounts to frame with out much difficulty. I use borgeson parts to gear box to column,with legal issues welding I would not. I have used toyota on bronco before,one from v-6 has larger pitman shaft. I had to find different arm for lock to lock steering
almustang
  #29 (permalink)
Old 10-27-2009, 10:37 PM
1994 Ford F-150
Check my album photos as far as looks goes. I have pics of manual and power.Is yours a 4x4?
  #30 (permalink)
Old 10-28-2009, 11:47 AM
p/s
Was a customers,over the years I have done both 2-4 and 4-4. A lot of willys and a few cars.
Al
Tags
1964 , 1966 , 62 , 64 , 66 , 78 , engine , f100 , ford , power , steering , truck , trucks , wheel , wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
