Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-03-2009, 02:26 AM
bobaloo11's Avatar
bobaloo11 bobaloo11 is offline
bobaloo11 is starting off with a positive reputation.
Clutch, Does it interchange?
I have a 73 ford chassis under my stepvan. It needs a new clutch in the NP435. It has a 3 finger pressure plate now. When I look for parts, all I'm finding is the diaphram type. Are they interchangeable?
__________________
UPDATED INFO...
1973 Olson Kurbmaster Stepvan.
On Ford P-400 Chassis. 300ci 6 cyl.
NP435 4 speed trans.
10,000 GVW
  #2 (permalink)
Old 10-30-2009, 11:59 AM
JoeP JoeP is offline
JoeP is starting off with a positive reputation.
The diaphram type clutch is supposed to give you a smoother release when you let out on the pedal. The down side is that they usually have less spring pressure the the three finger type. If I had a P-400 I would stay with three fingers. The three fingers are much more durable than the diaphram. We have had diaphrams incorrectly adjusted (not enough pedal free play) so that they push the fingers too far forward and damage the pressure plate. The little fingers on the diaphrams can bend, fall out and leave you with a clutch that will not release.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
