Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 10-02-2009, 09:08 PM
dddenio dddenio is offline
dddenio is starting off with a positive reputation.
Trans O/D light flashing
Just replaced transmission, but the OD light is flashing, where should I look? Any ideas?
2001 v10
__________________
02 7.3L Excursion 4x4 FTVB, MBRP 4" SS, Ranchos, "V" & "B" Codes, AirBags, Rear Hellwig, Coolant Filter Kit & 203 stat, Tank Mods 01 7.3L F350 CC LB 4x4 5" Exh guages BTS trans US Gear DP 6 pos chip V10 Trans Cooler Coolant Filter Kit Evans 203 stat DI reg Fuel GT38R BB Turbo AFE 2 Banks IC Air Bags
  #2 (permalink)
Old 10-02-2009, 09:52 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx is gaining momentum as a positive member of FTE.
bring it right back to the place you got it replaced. should have a warrenty? but you could pull the code and see what its doing.
__________________
My MPG http://www.fuelly.com/driver/alaskanford/excursion
'04 excursion xlt 4x4 v10 : 20" AR wheels, bull bar/HID driving lights, 6000k HID headlights, LED tails, x code/4" blocks, SCT3 tuned by 5 Star
'96 explorer limited 4x4 v6, many mods!
'94 explorer xlt 4x4 auto,6000K HIDs
'91 f-250 lairat 4x4 auto 5.0, custom paint..ect
  #3 (permalink)
Old 10-03-2009, 12:40 AM
Stewart_H's Avatar
Stewart_H Stewart_H is offline
Never fry bacon NAKED!
2002 Ford F-250
My Garage
Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold Stewart_H is a splendid one to behold
You need the code to ascertain why the trouble light was activated.
Like Alaska posted, take it back to the place that replaced the trans and have them diagnose it.
Stewart
__________________
The Brotherhood of FTE <~click the link
1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft
2002 PSD F250 SC 4x2: 38R, AC codes, Termy modded HPOP, MBRP 4", AFE, JWVB, Riffraff HPX, CCV, and boots, ITP OBA, Live Tuned by Jody
2000 PSD Excursion 4x4: John Wood 4R100, F5, MBRP 4", AFE, BDP 1.0, ITP OBA and Pre-Pump mod, V & B code springs, Hellwig rear sway
  #4 (permalink)
Old 10-03-2009, 10:41 AM
Sorry guys, I should have gave more info.
I bought a used trans from a reputable salvage yard with 36,000 miles on it and I need a little more info on this OD light flashing thing or how to pull the codes.
Thanks
Any trans guys on here?
__________________
  #5 (permalink)
Old 10-03-2009, 01:27 PM
Stewart_H's Avatar
2002 Ford F-250
My Garage
Mark Kovalsky posts here and he's a retired Ford trans engineer, but I'm sure he's gonna need more info just like we do.
You need to find someone with a PSD compatible code reader like a Predator, SCT Xcal II, or Auto Enginuity tool.
The regular scanners you can use at Autozone and Kragens don't work with the PSD's.
Once you find a scanner that will read your codes, post them up here or in the 7.3L PSD forum so we can help.
Stewart
PS - The reason the OD light is flashing is because you are setting a trans related code. The SES light in the dash is for engine related codes and the OD light flashing is for trans codes.
__________________
  #6 (permalink)
Old 10-03-2009, 05:09 PM
jpr38057 jpr38057 is offline
jpr38057 is starting off with a positive reputation.
Was the light flashing before you replaced the transmission? If it was the original code is still in there and needs to be cleared.
__________________
2004 Excursion V10
1979 MGB Limited
6 wild kids
People tell me I must have a lot of patience. I tell them I ran out of patience about 4 kids ago.
  #7 (permalink)
Old 10-03-2009, 08:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold Mark Kovalsky is a splendid one to behold
Stewart
That's what I would have said.
__________________
Mark
Former Ford automatic transmission engineer, 1988-2007.
  #8 (permalink)
Old 10-05-2009, 08:36 AM
Excursioncamp's Avatar
Excursioncamp Excursioncamp is offline
Excursioncamp is starting off with a positive reputation.
I too will be interested in the diagnosis of this issue. This happened to me for the first time (OD light flashing) on my '02 PDS while pulling through the Smoky mountains this weekend. I've pulled a 32 ft. trailer since 2003 and have never had any issues with the transmission.
I've got a DP Tuner with 40 HP tow, and I locked out OD for the mountain climb. Just a little while later, after OD was unlocked, I noticed it flashing, and when it shifted to OD, it was a very hard shift. After getting to the campground, shutting it down, then restarting it, I never had any problems all weekend long or on the way back home.
Not sure if my transmission is going out or some fluke happened. I've got 145k miles and usually it tows like a dream. I've had regular transmission maintenance performed, but may take it in and have it checked out soon.
  #9 (permalink)
Old 10-05-2009, 11:21 AM
When the original Trans failed it Displayed
These codes:
P1000
P0741
P1744
PO740
P0743
P0750
P0753
P0755
P0758
P1746
P1754
So I cleared these codes and all came up again except P0741 & P1744
These codes with new trans:
P1000
PO740
P0743
P0750
P0753
P0755
P0758
P1746
P1754
Mark, I'll edit this post and input the descriptions as well.
__________________
  #10 (permalink)
Old 10-05-2009, 12:51 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
2001 Ford Excursion
Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE. Toreador_Diesel has a good reputation on FTE.
New Codes:
P0740 Torque Converter Clutch Circuit Malfunction
P0743 Torque Converter Clutch Circuit Electrical
P0750 Shift Solenoid A Malfunction
P0753 Shift Solenoid A Electrical
P0755 Shift Solenoid B Malfunction
P0758 Shift Solenoid B Electrical
P1746 Electronic Pressure Control Solenoid - Open circuit
P1754 Coast Clutch Solenoid circuit malfunction
Old Codes:
P1744 Torque Converter Clutch System Stuck in Off Position
P0741 Torque Converter Clutch Circuit Performance or Stuck Off
__________________
FTE Excursion Forum Mod Death Row Inmate #21
2001 X PSD Limited, 6637 Filter, 203*, DP-Tuner NS/S/1200/80T/80E/120R, 4 inch MBRP, Aeroturbine Muffler, HPX, Sonnax/Tricum Kit, 26-row 6.0 trans cooler, '05 TT Mirrors, Crystaline Headlights, 6 inch PROcomp lift, 315/75/16 BFG All-Terrains, HIDs, 4.10 Gears, WW, SCT Code Reader.
If you live in Texas and need help with your truck, PM me.
  #11 (permalink)
Old 10-05-2009, 07:26 PM
It sure looks like the transmission harness isn't plugged in. Every solenoid is showing an open circuit.
__________________
Mark
  #12 (permalink)
Old 10-06-2009, 01:21 AM
2001 Ford Excursion
Quote:
Thats about what I figured too....
__________________
Tags
01 , 1999 , 2001 , 73 , blinking , duty , excursion , f150 , flashes , flashing , ford , light , od , overdrive , super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
