Truck dies out when step on brake
Check your carb float level. If float is set too high, you can get fuel slosh out the vent tube and it goes down the carb and floods the engine. At least that can happen on a Holley, not sure about Ford carbs.
Another possibility is if you have a dashpot to slow the carb return to idle rate down, it could be shot. Try it in the driveway. Momentarily open the throttle by hand with the engine running, and then let it go. It should return to almost idle quickly, then slow down and the proper idle will come on slowly.
Dash Pot shot ? If it has one the diaphragm may have gone to greener pastures letting the throttle arm slam closed rather than easing to it's seat.
http://www.allfordmustangs.com/forum...lp-dashpot.jpg
Whoopser! I see Argess covered that already.
Could it be the brake booster?
the booster looks like its the OEM same with the master cylinder.
it seems like the motor looses vacuum when i step on the brake also.
I had that issue on my 73 F-250. When the brake boost went out the engine would run badly and die. I also had a terrible time trying to stop it. Are you having any braking issues? If you are replace both the master cylinder and brake boost at the same time. They usually go out relative close to one another.
Don't replace that booster just yet...there may be nothing wrong with it.
1968/72 F100/250 power boosters have a replaceable vacuum check valve. This valve fits into the booster using a rubber grommet.
What happens: The rubber grommet hardens up, then cracks apart...now you have a vacuum leak.
The valve may have failed as well.
DOAZ2365A .. Vacuum Check Valve / Available from Ford
MSRP: $10.67 // FTE sponsor Y2KFORDPARTS.COM price: $5.76.
C9AZ2B176A .. Check Valve Rubber Grommet / Obsolete
MILLER OBSOLETE PARTS in Binghamton NY has TWO = 800-546-7278.
MARLEY GROSS FORD in Spring Hill PA has TWO = 717-225-4765.
BOB ALLEN FORD in Overland Park KS has TWO = 800-676-0675.
GREEN SALES CO. in Cincinnati OH has THREE = 800-543-4959.
zus009
07-10-2017 06:16 PM
kaluahili
04-18-2017 12:35 PM
csharris
05-01-2016 03:42 PM
Spitfire44
08-23-2004 10:13 AM
