2011 Ford F450 Super Duty: Loses Weight, Gains Better Gas Mileage article - Page 5 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #61
Old 03-02-2011, 01:30 PM
sideshow's Avatar
sideshow sideshow is offline
sideshow is gaining momentum as a positive member of FTE.sideshow is gaining momentum as a positive member of FTE.
I didn't necessarily NEED a F350, but figured I'd be safer should I ever get weighed or be in an accident where GVWR would have exceed that on the F250. I had replaced the rear block on the F250 anyway, but when looking for a lightly used truck, found no difference in price between the 250's and the 350's.
Just sold my 02 F250, and traded an 05 F350 SRW King Ranch in on an 08 F350 SRW KR. both have/had the 11400 GVWR. the 05 had the camper package with rear sway bar, the 08 doesn't. not sure what the difference in the two is aside from that. Here in NC, or at least with Farm Bureau, insurance is CHEAPER (requires a business auto policy). My insurance is 250 bucks a year cheaper on this 08 than it was on my 02 F250 with 8800 GVWR. I have weighted tags at 20k lbs, will up to 24k or so upon renewal.
Just checked, Rear AWR is 6900 and front is 5600, how does that compare to the 2011's?
  #62
Old 03-02-2011, 01:53 PM
Anomic Anomic is offline
Anomic is starting off with a positive reputation.
Quote:
Originally Posted by Kenworth View Post
Who in their right mind would be going the speeds Ford thinks the truck will be. H*ll I don't take my 03 F-450 more than 100km/h (62 mph) a 9700lb truck starts to float at those speeds.
There was a thread here a few days ago about a guy wanting a mid 90s 460 motorhome regeared becuase it was to loud driving "for hours at 65mph"
Im with you even my 250 doesnt go over 65. Gives you a bigger safety margin
  #63
Old 03-02-2011, 03:38 PM
78bigbronco's Avatar
78bigbronco 78bigbronco is offline
78bigbronco is gaining momentum as a positive member of FTE.
Quote:
Thats basically my thoughts as well. Unlike most who need SD's for towing, I haul mainly so thats why I got an 8' bed and a 350. I know alot of times I am bordeline with the 350 ratings and sometimes way over, so atleast the higher ratings would get me out of a $$ fine or atleast less of a fine. The cost wasnt much difference and neither is our local registration or insurance between the two.
2011 Ford Super Duty: Fifth Wheel and Gooseneck Tow Hitch article Ford-Trucks Editors Fifth Wheel & Gooseneck RV Towing 8 04-15-2010 02:21 PM
Ford 2011 Superduty Photos and News on the homepage Ford-Trucks Editors 1999 to 2016 Super Duty 30 12-15-2009 08:00 PM
2011 Ford Super Duty Live Drive PTO Ford-Trucks Editors 1999 to 2016 Super Duty 4 10-02-2009 02:08 PM
2011 FORD SUPER DUTY ELECTRONIC REAR DIFFERENTIAL LOCK article Ford-Trucks Editors Clutch, Transmission, Differential, Axle & Transfer Case 0 10-01-2009 03:30 PM
2011 Ford Super Duty Trailer Sway Control article Ford-Trucks Editors Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 0 09-30-2009 04:36 PM
Tags
2008, 2011, 450, duty, f450, ford, gas, milage, mileage, order, photos, super, truck, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
