2011 Ford F450 Super Duty: Loses Weight, Gains Better Gas Mileage article - Page 3 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
  #31
Old 12-31-2009, 08:00 AM
ruschejj's Avatar
ruschejj ruschejj is online now
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
I'll never need a 450 but I am concerned about the Super Duty line. A few things happening here, I think:
1. Appears Ford thinks the 450 is an opportunity to sell trucks because it has a number higher than 350/3500. Kinda like wearing a golf shirt with a Nike swoop on it.
2. Ford looks to make a higher profit margin by using more shared parts in the SD line.
3. Ford thinks it can hide behind the "MPG gains" and hopes all of us will forget about metal and gears.
This makes me angry. I wasted money on 3 GM branded trucks before I found the SD. My 250 is perfect for me and my work, a 350SRW is probably next for me to gain just a little safety over the 250 when towing. I am worried that the whole line will start to get lightened, weakened, and less useful.
  #32
Old 12-31-2009, 09:41 AM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
I don't see that happening, Joel.
In 2011 we will still have our solid front axle, beefy frame, bulletproof rear axles, big brakes, HD transmissions, high-output engines, etc.
The current F450 has a rear axle that's rated for 11,000 lbs, while the axle on the F350 is rated for 9,000 lbs.
But why can't that Dana M80 support 11,000 lbs? I mean, the only difference between the -250 and -350 SRW trucks is the door stickers, but just that seems to be worth an increase of 1,000 lbs on the rear axle!
4 E-rated tires are still rated at over 12,000 lbs capacity in dually form...so why does the downgraded axle mean that it wouldn't be safe handling the same loads? Maybe it's possible that the S110 axle was simply overbuilt for the application and the average pickup F450 buyer didn't need that capacity.
  #33
Old 12-31-2009, 12:02 PM
smlford's Avatar
smlford smlford is offline
smlford has a good reputation on FTE.smlford has a good reputation on FTE.
I'm sorry but anyone who doesn't mind paying more for fuel is an idiot...
I have 2 Mack tamden dump trucks and get aboout 5 MPG. If I could get more MPG's I'd be all over it. Unless you're a Shiek your stupid not to want better mileage out of your "fleet".
For those of you that are bemoaning the capabilities of the F-450's maybe you should be looking for a heavier truck like a Freightliner FL60 that will tow any 5th wheel out there AND get better fuel mileage to boot.
The right tool for the right job...
Here's a great example...
2003 FREIGHTLINER FL60 Versatile Hauler Truck For Sale At TruckPaper.com
Have a Happy New Year!
  #34
Old 01-01-2010, 07:25 PM
Guardrail22 Guardrail22 is offline
Guardrail22 is starting off with a positive reputation.
Everyone wants more MPG. No question. But NOT at the expense of strength and safety. If you have an F450 for towing and it scales 14500# loaded then you need an F450, not a decontented excuse for an F450 that will only gross out at 13000#.
The fact mileage could easily be gained with better aero, a rethinking of the DPF technology and its regen and different gearing - such as a six speed AT that only uses the first 5 gears for towing.
My F450 weighs nearly 10000# full of fuel (60 gal) and taking out the Dana 110 and the big tires and brakes means I can't use it any more.
  #35
Old 01-26-2010, 12:22 PM
blue66tang95f150 blue66tang95f150 is offline
blue66tang95f150 is starting off with a positive reputation.
I wish they would just drop the f450 pickup version, and leave that name to the cab and chassis version. I also think they should drop the lame "super duty" name, because really, what other duty is out there? So why not call the 250 350's what they are. Just standard f250s and f350s and call the now f450 "neutered version" a super duty f350. That way the "super duty" will actually mean something. Remember back in the mid 90s we had the standard f250 and f350 and then the "super duty", F-450. At least "super duty" actually meant something
  #36
Old 01-26-2010, 01:54 PM
Ace!'s Avatar
Ace! Ace! is offline
Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.Ace! has a good reputation on FTE.
Chev/Dodge call their 2500/3500 "Heavy Duty".
  #37
Old 01-26-2010, 02:52 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
It's just marketing... However, I love the "Super Duty" name!
  #38
Old 01-26-2010, 08:26 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
i also like the moniker of the superduty...
its what helps some people understand its more truck then a F150...
  #39
Old 01-26-2010, 09:38 PM
My point exactly! Its all just marketing! If they all call them super dutys or heavy duty, whats the standard duty? We all know a f150 is lighter than a 250 and 250 lighter than a 350 yatta yatta yatta. So whats the point in the name. I feel sorry for the people who get dooped into buying a truck because its a "super duty" over a "standard duty" that doesn't exist.
Any way just my rant. If they call the thing a f 450. I think it should be the same gvw or have options to make it the same gvw as the cab and chassis. It was always nice to have the F450 and F550 separate than the F250 and F350.
  #40
Old 01-27-2010, 01:16 AM
Furian's Avatar
First there was "Heavy Duty". Then came "Super Duty". What do you think the next name will be... "Extreme Duty?"
  #41
Old 01-27-2010, 08:43 AM
edjunior's Avatar
edjunior edjunior is offline
edjunior is gaining momentum as a positive member of FTE.edjunior is gaining momentum as a positive member of FTE.
I vote for "Super Duper Duty"!
Okay, I'll shut up.
  #42
Old 01-27-2010, 05:34 PM
Patrick11's Avatar
Patrick11 Patrick11 is offline
Patrick11 is starting off with a positive reputation.
Quote:
Originally Posted by dkf View Post
So you spend over $50k for a shiny new F-450 and over $40k for a big ole fiver to pull behind it and your really concerned about a couple mpg? Sorry don't make sense to me at all. Drive a small car or hybrid and stay in a motel it will be a lot cheaper.
I didn't realize top speed was such an issue. I don't know why you'd want to go over 80mph with a heavy trailer anyway. Tires can easily withstand short term use over there speed rating anyway. I'd rather have the 19.5 12 ply tires.
Apparently You've never been to Massachusetts or Jersy! hahahaha
  #43
Old 01-27-2010, 08:36 PM
Even if you do spend a ton of money to buy a new truck and trailer, you should still want good mpg. Why would anybody, even if they have a ton of money, want to waist money on fuel. Heck I spend 1000+ dollars a month on fuel, so any kind of MPG increase helps. Just going from 10-12 pulling a trailer makes a huge savings in fuel. I would much rather spend that extra savings on something else for my business. So there is nothing wrong with wanting extra MPG!
  #44
Old 01-27-2010, 11:46 PM
Ace!'s Avatar
There's nothing wrong with it, but if you think you can buy a truck with more weight and lower gears and not have mileage suffer you're not thinking things through. A lot of people (I know a few) will buy the biggest truck they can, regardless of whether they tow. It's a "status" symbol, like a Rolex watch. F450s and Rolex watches are nice, but most people don't "need" them to get the job done, they want to get the job done and get noticed at the same time.
  #45
Old 01-27-2010, 11:53 PM
Furian's Avatar
Quote:
Cough... Cough... That would be me! Hey, I love my F350 and I don't complain about the MPG's because that's part of owning one of these monsters. Isn't it still great living in America!
2011 Ford Super Duty: Fifth Wheel and Gooseneck Tow Hitch article Ford-Trucks Editors Fifth Wheel & Gooseneck RV Towing 8 04-15-2010 02:21 PM
Ford 2011 Superduty Photos and News on the homepage Ford-Trucks Editors 1999 to 2016 Super Duty 30 12-15-2009 08:00 PM
2011 Ford Super Duty Live Drive PTO Ford-Trucks Editors 1999 to 2016 Super Duty 4 10-02-2009 02:08 PM
2011 FORD SUPER DUTY ELECTRONIC REAR DIFFERENTIAL LOCK article Ford-Trucks Editors Clutch, Transmission, Differential, Axle & Transfer Case 0 10-01-2009 03:30 PM
2011 Ford Super Duty Trailer Sway Control article Ford-Trucks Editors Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 0 09-30-2009 04:36 PM
Tags
2008, 2011, 450, duty, f450, ford, gas, milage, mileage, order, photos, super, truck, weigh, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
