Removal and Installation
1. CAUTION: Use a shop towel or similar device to protect the vehicle finish when carrying out the procedure. Remove the rear window wiper pivot arm.
o Lift the pivot arm nut cover.
o Remove the nut.
o Using a suitable 2-leg gear puller, remove the rear window wiper pivot arm.
o To install, tighten the nut to 12 Nm (9 lb-ft) .
2. NOTE: This step makes sure that the wiper motor is in the PARK position. Turn the rear window wiper switch ON and allow the motor to operate for at least one cycle. Turn the rear window wiper switch to OFF.
3. To install, reverse the removal procedure.
o Adjust the rear wiper pivot arm.
__________________
2008 Expedition Eddie Bauer 4x2
1978 F250 Lariat 4x2
