disc/disc conversion?...
I think I just got jammed up......a little...maybe...
For a disc/disc conversion with a complete replacement underfloor unit using
a corvette style, 1" bore Master cylinder and a 7" dual Diaphragm Booster, bracket
and pedal assembly that mounts in the "original" location as to retain the OEM pedal location/look...
WHAT exactly is gonna screw me up...I mean besides me...?
I may have "overlooked" this small...yet...oh-so-important issue...
Thanks...
Thanks...
That's a good question! Maybe a 6 pack of Cold Frosties?
I'm not sure, but I'm starting to think about doing it to my 51 if for noother reason to change the front bolt pattern to match the back (ooops, got the right size wheels?)
Here's a link to a thread from awhile back where the guys tossed around some ideas. Maybe if you read through it the lost item may be mentioned - not sure. If nothing else it will bump this back up - good luck!
https://www.ford-trucks.com/forums/8...ml#post7689968
What OldF1 said..and Julie said,..plus maybe an "adjustable "proportioning valve so you can get that confidant feeling when sliding into turns and stabbing the brake pedal,..and maybe a box of Band-aids...a quality brake-line tube bender with a tight (1") radius,1/2 doz 3/16 stainless brake-line clamps,4 -six foot pieces of 3/16 brake-line and what ever flex hoses and crush washers....you might be up to a 12 pack by this point..Have Fun!
Kinda...Sorta...
...well...that clears it up some...THANK YOU ALL!
I guess I was lookin' to see if anyone has installed one of these...
Classic Car and Truck Brake, Steering and Suspension Parts
..and how the whole thing went...
Maybe not this exact kit...but you get the idea...
hoagie48
01-15-2014 08:12 AM
IAmKevin
05-30-2013 12:07 PM
