Heater won't work - Ford Truck Enthusiasts Forums
Heater won't work
Old 10-01-2009, 12:23 PM
scotty_fred scotty_fred is offline
scotty_fred is starting off with a positive reputation.
Heater won't work
Everytime I turn my temp. dial to hot it makes a clicking noise...I googled the problem and seen it was a "heater control?" If anyone could help I would really appreciate it...Thanks
Old 10-01-2009, 06:26 PM
marragtop's Avatar
marragtop marragtop is offline
marragtop is starting off with a positive reputation.
What year is it?
Old 10-01-2009, 09:23 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
the hot **** controls a electric motor that moves a hot air mixing door inside the duct. not uncommon for the door or arm on the door to break with extended use. Old style and new style "blend doors" vary by age of the truck. Like ragtop said, what year? Or you can search for "blend door" on the site.
Old 10-02-2009, 01:52 AM
2004 Explorer XLT....Are they hard to change? Thanks
Old 10-02-2009, 02:45 AM
Wow I searched the site and found the heater treater thing on ebay is the way to go....I will try it and let you guys know how it turns out.....Thanks a million guys I was in the dark on this one!
heater shut off valve bigbubba87 1999 - 2003 7.3L Power Stroke Diesel 20 10-10-2012 06:55 PM
Heater Core Replacement JasonBrod 1997 - 2003 F150 5 10-04-2012 02:05 PM
Block Heater Power Consumption cowmilker08 1994.5 - 1997 7.3L Power Stroke Diesel 21 02-15-2012 10:47 PM
1985 f250 heater core f150rd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 12-19-2011 07:55 AM
Block Heater Watts QUINCE 6.0L Power Stroke Diesel 3 11-06-2008 10:40 AM
Tags
2000, 2002, 2009, change, controls, explorer, ford, heater, idle, ranger, sport, trac, treater, truck, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
