Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
General Diesel Discussion SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 10-01-2009, 12:43 PM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is online now
muscletruck7379 is starting off with a positive reputation.
aluminum 3-53t
anybody ever been around one of these old 2 strokes? found an all aluminum 3-53t (out of a military gama goat) with clutch and everything and it got me to thinking, and i think im gonna make an offer on it. from what i have found online is that they make 120 hp, but wasn't able to find a torque spec.
what would be a good home for this engine? how much weight do you think it could handle? and would it be possible to turn it up high enough for my highboy?
you can get jakes for them too...
__________________
1973 f250 highboy 4x4
1984 full size bronco, megasquirted 300 on the way!
1988 f150 extended cab 4x4
1984 mercury capri, 5.0 conversion
1961 ford falcon, all stock, in family since '68
  #2 (permalink)
Old 10-01-2009, 02:31 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE. 85e150six4mtod has a great reputation on FTE.
Google my man:
Diesel Engine Specs
Note that it weighs 1000 lbs in iron, so what, 750 in pot metal?
131 hp at 2500 rpm, which translates to 275 lb/ft at the same rpm, and my guess is 2500 is about it rpm wise.
Horsepower Design Equations Formulas Calculator - Torque Rotating
And it's a 3 cylinder, so get your lock nuts and Loctite out.
With that rpm range, you will need something like a Ranger or GV OD to have enough gears to get to highway speeds, or install a really tall axle, and suck wind when you shift it and go from redline to idle....
Some discussion of this engine and others, note bellhousing comments:
http://www.4btswaps.com/forum/showthread.php?p=56118
JMO< YMMV, YMYTYT,IYM.
  #3 (permalink)
Old 10-01-2009, 08:20 PM
nevrenufhp nevrenufhp is offline
nevrenufhp is starting off with a positive reputation.
The aluminum version would be a good score if you had a truck to put it in. Go look on youtube, there's a few Detroit swaps. Only a couple are the aluminum version. Go for it, and buy a cheap F350 to put it in. A Roadranger RT610 would fit in a pickup, and give you 10 speeds. You would just have to have highway gears to use it since it's not overdrive, but they do make an overdrive for it aftermarket, or you can find an actual RTO610.
__________________
turn up diesel fuel rate site of mine
67 F100, 300, 4spd, Offy 'C', Edelbrock 500, heddder.
  #4 (permalink)
Old 10-01-2009, 09:59 PM
i have my 73 f250 highboy that i would like to build into a diesel, but i don't really think that the 3cyl would have enough in it to make up for even the 360 (maybe if it was a 6v53).
and i hate overdrives, its makes much more sense to run a lower 1st gear (like with the 10 speed) and a higher gear in the rear.
__________________
  #5 (permalink)
Old 10-01-2009, 10:08 PM
A bone stock 3-53, maybe not. There's a lot of stuff you can do to em to crank out some power. At 130hp, it would feel close in power to the 360. Add bigger injectors and turbo.....happy drivin!
__________________
  #6 (permalink)
Old 10-02-2009, 12:23 AM
Last edited by 85e150six4mtod; 10-02-2009 at 12:24 AM. Reason: lost my mind for a moment
  #7 (permalink)
Old 10-02-2009, 07:31 AM
tjc transport's Avatar
tjc transport tjc transport is offline
oh no, not again!!
tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation. tjc transport has a spectacular reputation.
a 3-53T would move a 73 highboy pretty good with a 4 or 5 speed trans.
search you tube. there is a fellow with a non turbo 3-53 in a mid 60's chevy that runs and sounds awesome.
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of way too many fords.
  #8 (permalink)
Old 10-02-2009, 09:18 AM
jas67 jas67 is offline
jas67 is starting off with a positive reputation.
How 'bout a Cummins 4BT/.
Quote:
I believe that the 3-53T has a turbo (isn't that what the 'T' stands for)?
For alternatives, check out:
http://www.google.com/url?sa=t&sourc...o38HPZHmfPRykA
  #9 (permalink)
Old 10-02-2009, 12:04 PM
sorry. I didnt see that til after the post was made.
__________________
  #10 (permalink)
Old 10-02-2009, 12:13 PM
that was my bad, it doesn't have a turbo.
__________________
  #11 (permalink)
Old 10-02-2009, 06:10 PM
101 hp/189 lb/ft at 2800 rpm....a 300 six would be like a pro-stocker compared to that....
  #12 (permalink)
Old 10-04-2009, 01:44 PM
But...a 300 doesn't sound like a 3-53! Adding power is easy
__________________
  #13 (permalink)
Old 10-04-2009, 01:45 PM
It doesn't shake and leak oil like one either, I bet....
  #14 (permalink)
Old 10-04-2009, 01:49 PM
you got me on that!
That's what I'm afraid of with my 4BT swap. Noise and vibes, when I'm used to a smoooth 300.
__________________
  #15 (permalink)
Old 10-04-2009, 01:58 PM
Big 4 cylinder = big vibes, up and down at 2x crank speed, iirc.
Get the lock washers out....
With luck, your gearing will put it at a running speed that doesn't harmonize with some other vibration. Your teeth could need to be cross-bolted to hold your fillings....
Tags
353 , 353t , aluminum , detroit , diesel , hp , spec , specs , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
