__________________
Shawn
The Republic was not established by cowards; and cowards will not preserve it ... This will remain the land of the free only so long as it is the home of the brave. Elmer Davis
first, my horse trailer is starting to rust in several spots...short of shelling out $1500 to have it completely redone (which i can't), what's the best approach to sanding/priming etc to keep it in check?
then- how difficult is it to replace ac clutch/compressor and flush brakes?
__________________
"she's not crazy, just a little misunderstood"
1996 F250 XLT 7.3L PSD SC/LB 4x4, auto, 4.10 rear/busted 3.55 front, 4" suspension lift on 37" Goodyear Wrangler MTs, 6637 air filter, 202k+ mi and counting
Plotting: 4.10 conversion, stacks, gauges, tw chip, cat/muffler delete, and more that won't fit
I've been very impressed with using POR-15 on my axle and parts. . .
a $25 "sample pack" is really a kit that does 12 square feet. it includes everything you need. . .cleaner, brushes, gloves, instructions, and paint. Really depends on where it is rusted though. . .if its rusting at seems or joints you really need to get it apart to wire brush and at least hit it with an Ospho like rust converter and quality zinc rich primer. . .
flushing brakes is time consuming. . .not really hard unless your bleeder screws are rusted in tight
not sure about the AC clutch. . .I took it out of my red truck and it wasn't too bad. . .and I take for granted my 2004 AC just works :P
__________________
Steve
2004 F150 STX
1978 F-250 4X4
1987 F-250 4x4 VIRGINIA CHAPTER Virginia Chapter Website
