map sensor line
What is this you are talking about?
See the T piece to the left of the spider. Thats my boost gauge which is tapped into the Map sensor line.
Now the AIH delete is removal of the plug you can see that goes into the left tube of the spider, just to the right of the T. with the wire attached to it. You put one of these cool lookn plugs from Clay
Riffraff Diesel: RDP AIH Tapped Fitting
and you are good go. It is threaded so you can instal your boost gauge there. It removes some restriction from the internal of the spider and one less cable. But more importantly - it looks good
PRIMERED79 SHORT BED
12-23-2016 05:48 PM
Jmanb13
09-19-2015 07:48 PM
