Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Ford Inline Six, 200, 250, 4.9L / 300
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-30-2009, 03:57 PM
gloorm gloorm is offline
Garage is empty, add now
gloorm is starting off with a positive reputation.
I6 trans/t-case combos
I had a 92 1/2 ton that was totaled.....i cried. it had an i6 but the motor had 2 b junked. my current truck has a 5.slow in it. I was wondering if a friends 300 carb with a 3 spd manual floor shift would bolt up 2 my electronic select t-case. my truck is a 95 with an auto. wht trans did the 300 bolt up 2. the trans i have is an aode. would it mate up with that. I love the bigsix and need a good project.
  #2 (permalink)
Old 09-30-2009, 11:10 PM
4.9ohiostyle 4.9ohiostyle is offline
4.9ohiostyle is starting off with a positive reputation.
I'm no expert on this subject, but I think I have read that any trans from a 302/351 will bolt to a 300. Not positive but I'm sure someone will tell ya if I'm wrong. Good luck with the project.
  #3 (permalink)
Old 10-01-2009, 02:57 AM
johnboy427's Avatar
johnboy427 johnboy427 is offline
johnboy427 is starting off with a positive reputation.
The 300 will bolt up to a 302s transmission you will need the flexplate for the 300. Is the three speed out of a 4x4?
-Johnboy
  #4 (permalink)
Old 10-01-2009, 09:42 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
1981 Ford Bronco
AbandonedBronco has a good reputation on FTE.AbandonedBronco has a good reputation on FTE.AbandonedBronco has a good reputation on FTE.
The 300, 302, and 351 all shared the same transmissions.
However, if you do the swap, you'd be best served by swapping in a manual transfer case as well! Those auto ones like to give out at the most inopportune times...
__________________
1981 Ford Bronco. 300I6 Offenhauser DP Intake Holley 600 4bbl, 31" BFG A/T, NP435, 3.00 rear 9" EFI Manifolds. 2.5" high flow cat/muffler.
1984 Ford Bronco. 300I6 Offenhauser C Intake Holley 600 4bbl, 31" BFG A/T, NP435, 3.55 rear 8.8" EFI Manifolds. 2.5" high flow cat/muffler.
Supermotors Pics
  #5 (permalink)
Old 10-02-2009, 11:41 PM
the 3 spd is a 2 wheel drive...will i run into n e problems with mating a carb. moter 2 a electronic trans?
  #6 (permalink)
Old 10-03-2009, 12:31 AM
johnboy427's Avatar
It will not bolt up directly you will have to find a tail housing from a three speed out of a 4x4 and even then I don't know if it will share a bolt pattern with you transfer case. I am still wandering why you don't just bolt your 300 to the transmission you already have? If you are going to do a transmission swap I would go for a ZF 5spd, don't get me wrong the little 3.03 is a great tranny but granny low and over drive are nice to have. This swap isn't going to be a bolt in at all you will have to fabricate stuff your self, and why go through all the trouble just to have a three speed. If you pick a transmission that was avalible from the factory they you are looking for parts not making them. Your electrically shifted transfer case should work fine with your carbed motor.
-Johnboy
  #7 (permalink)
Old 10-05-2009, 01:06 PM
i never really planned on putiing the 3 spd in. the only reason i would consider it is if i would have problems mating the carb. motor 2 the AODE transmission. And by the way does ne body have a link 2 a thread that details a 300 build up or a website that sells performance parts 4 a 300?
  #8 (permalink)
Old 10-05-2009, 01:13 PM
1981 Ford Bronco
You can check out my supermotors pictures. Each one should have information at the bottom.
I did it in 2 parts. First was the exhaust (still had the 1bbl).
Exhaust Upgrade
Next was the 4bbl conversion.
Four Barrel Conversion
Cliffordperformance.net sells some performance parts, but they can get spendy.
__________________
Supermotors Pics
Tags
1981, 300, 303, bronco, case, combos, f150, ford, i6, transfer, transmission, transmissions
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
