Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Massachusetts Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
  #1 (permalink)
Old 09-30-2009, 01:05 PM
GUNNERDOG's Avatar
GUNNERDOG GUNNERDOG is offline
Garage is empty, add now
GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.GUNNERDOG has a very good reputation on FTE.
Broken exhaust manifold stud on an out-of-warranty truck?? Check the warranty again!!
If your truck is registered in Massachusetts you may be eligible for the "California extended emissions warranty" which covers, among other things, replacing broken exhaust manifold studs.
--A brief history--
I discovered a broken stud on my exhaust manifold a few weeks ago and started reading up in the forums about how to replace them. I discovered that it was going to be quite a task to get them out and it might even require lifting the engine block to get to some of them. The studs themselves cost about $12 each from ford, so for a V10 it costs $120 per side just for hardware.
Luckily one day i stumbled accross a link to the factory warranty for my truck (a 2003 F-250 with 65k miles.) Of course the standard 3/36 bumper to bumper warranty expired back in 2006, but a section called "California emissions warranty" cought my eye. It stated that the components in "the table" were covered for 7 years and 70,000 miles!!!! "Applicable if your vehicle is certified for sale in California and registered in California, Maine, Massachusetts, New York or Vermont." and the exhaust manifold was in the table.
After 45 minutes of arguing on the phone with the service manager (who finally contacted ford for clarification) he agreed to fix the manifold under warranty. (he tried to get out of it on a technicality saying that the manifold studs are not part of the manifold and therefore since the manifold was not cracked it was not covered. He was wrong.)
I got my truck back a few days ago and they had replaced ALL the bolts AND the manifold on the passenger side (the side that had the bolt missing).
SO, check your exhaust manifolds and read your warranty CAREFULLY. Here is a link to where you can download your warranty info:
****Warranty Lookup****
good luck
__________________
2003 F-250 XLT SC SB 4x4 6.8L 3.73LS w/2008 Bed
You might be an engineer if ... the first thing you do with anything new is take it apart to figure out how it works.
  #2 (permalink)
Old 09-30-2009, 09:21 PM
donjamer's Avatar
donjamer donjamer is online now
2006 Ford F-350
donjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputationdonjamer has a superb reputation
Great info Justin...
Glad it worked out for you..
Hopefully someone else can benefit from it..
__________________
Don #3 SlackMaster
Chapter Leader of the Massachusetts Chapter
Join the MA Chapter Here
Currently own:
2006 F350 Lariat CC Super Duty, 6.0 L Diesel
FTE Fraternity OF Blue Max
Tags
2008, 2009, bolt, broken, cracked, exhausr, exhaust, f150, ford, manifold, missing, powertrain, replace, stud, studs, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
