2004 Explorer Clicking Noise in Heater
Old 09-30-2009, 12:34 PM
scotty_fred's Avatar
scotty_fred
scotty_fred is offline
My heater makes a clicking noise when I turn the heat on..If I turn the temp. to cold it won't do this..Any suggestions...Thanks
Old 10-23-2009, 08:06 PM
thecardoc's Avatar
thecardoc
thecardoc is offline
Most likley the blend door actuator motor gears striped
Old 10-23-2009, 08:16 PM
scotty_fred
is there a way i can manually open it? i don't have the cash to fix it right now...and i live in Ohio so i need heat now...thanks
Old 11-05-2009, 07:22 PM
thecardoc's Avatar
thecardoc
If you open the glove box then squeeze the sides in a bit the glove will drop all the way open to the floor . Then with a mirror you can see the right side end of the blend door shaft i t has a two inch long lever on it . This lever contacts a vacuum valve when the blend door is fully open . You can "help " this lever along a little while the actuator motor is clicking to get past the the bad spot of stripped gears to put the blend door in full heat position. The permanent repair is to replace the blend door actuator motor . Available at many places auto zone napa advance for about $45.00 It is fairly easy to replace about 45min to an hour .
Old 12-01-2009, 12:02 PM
scotty_fred
I can't see the shaft?? Only thing I see is the lever that changes from defroster to floor/vent?? Any hint to what I am looking for?? Thanks
accent2010
Escape & Escape Hybrid
03-10-2017 03:22 PM
Zareen Shahin
New Member Introductions
06-12-2016 08:52 PM
osornio78
1997-2006 Expedition & Navigator
07-27-2010 10:26 PM
scotty_fred
02-10-2010 06:16 PM
kkoles2000
19
07-08-2003 07:51 PM
Quick Reply: 2004 Explorer Clicking Noise in Heater
