Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-30-2009, 01:34 PM
scotty_fred scotty_fred is offline
scotty_fred is starting off with a positive reputation.
2004 Explorer Clicking Noise in Heater
My heater makes a clicking noise when I turn the heat on..If I turn the temp. to cold it won't do this..Any suggestions...Thanks
  #2 (permalink)
Old 10-23-2009, 09:06 PM
thecardoc thecardoc is offline
thecardoc is starting off with a positive reputation.
Most likley the blend door actuator motor gears striped
  #3 (permalink)
Old 10-23-2009, 09:16 PM
is there a way i can manually open it? i don't have the cash to fix it right now...and i live in Ohio so i need heat now...thanks
  #4 (permalink)
Old 11-05-2009, 08:22 PM
If you open the glove box then squeeze the sides in a bit the glove will drop all the way open to the floor . Then with a mirror you can see the right side end of the blend door shaft i t has a two inch long lever on it . This lever contacts a vacuum valve when the blend door is fully open . You can "help " this lever along a little while the actuator motor is clicking to get past the the bad spot of stripped gears to put the blend door in full heat position. The permanent repair is to replace the blend door actuator motor . Available at many places auto zone napa advance for about $45.00 It is fairly easy to replace about 45min to an hour .
Tags
04 , 2003 , 2004 , 2005 , clicking , clicks , control , exploer , explore , explorer , ford , heater , make , making , noise
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
