Lift and tires for F-250 - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-30-2009, 09:48 PM
Furian's Avatar
Furian Furian is offline
You Keep What You Kill
Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.Furian has a great reputation on FTE.
Old 09-30-2009, 10:16 PM
420CREW's Avatar
420CREW 420CREW is offline
420CREW is starting off with a positive reputation.
Really good links I am in the same boat
Old 09-30-2009, 11:53 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
If you have a limited amount on your budget i would suggest sticking with your stock wheels and going to a narrow 33 or 34" tire. Tirerack.com will get you started on some tire ideas. If you decide to go larger (35" or higher) you may want to go with the leveling kit as mentioned. Be aware there is more to just adding tires wheels and lift/level kit. To do all of this correctly and properly you could easily be into $2500 and up. Include wheel/tire, lift, mounting, balancing, alignment, installation etc.. If you do all this you will probably want or need to purchase new/performance shocks, stabilizer, possibly track bar etc...
Seeing as you have the 250 and decide to go with a leveling kit (2.5" for example) you may realize you will want/need to lift the rear to level the truck resulting obviously in additional costs.
Set goals for the truck that you want and take your time to research all the possibilities and options. Purchase the items you decide on in intervals until you have what you want. You will loose performance and economy period. That is the price you pay for modifying it. Additional costs will be involved to recoup the performance but your economy will typically never return.
If you really need tires now, purchase some new stock or 275/285 tires and in the meantime do your homework.
Old 10-01-2009, 12:14 AM
Firekite's Avatar
Firekite Firekite is offline
Shining Adonis
Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.Firekite has a great reputation on FTE.
Quote:
If got pretty much the same truck as the OP: 2007 F250 Super Crew FX4 Lariat 6.0L PSD as well. I've seen leveling kits from 1.5" to 2.5", and sometimes the 2.5's with 1" blocks for the rear, which leads me to believe there's a 1.5" discrepancy from the factory, but you can bump it up a little more if you raise the rear as well. Basically the same thing as a budget boost for the Jeep (Wrangler).
Would this be accurate? That a 1.5" lift in the front brings it level, a 2" is slightly higher in the front, and the 2.5" needs a 1" in the rear to level it out again?
Old 10-01-2009, 12:30 PM
Furian's Avatar
Solid advice! That's exactly what I'm doing. I was in the same position when I purchased my F350 last year. The truck was bone stock and needed new tires. I had a general idea about what mods I wanted to install (tires, wheels, lift kit, etc) but did not want to commit to the mods to later determine they were not what I really wanted. So I installed new Michelin AT2's (stock size) and started my research.
I started out thinking that I wanted 35" tires and a 4.5" Icon lift kit. This is a very popular combination for good reasons. However, I wanted something more hardcore. I then decided on 37" tires and a 7" Icon lift kit. However, 37" tires and taller are too large for the OEM fender wells so I started looking at how I could resolve this issue. I then decided on 40" tires and Bushwacker "cut-out" fender flares. The COFF's would allow me to install very large tires with minimal lift. This would improve handling and access to the cab and bed.
I've already purchased 18x10 Ion Terminator wheels, 40" MT Baja Claw tires, the Bushwacker flares, Mag-Hytec front & rear differential covers and transmission cover, new headlights, and a new grille but I haven't installed anything. I know that I want Yukon 5.38 gears and Eaton differentials, which will be the next purchase. I'm still undecided about the lift kit but am looking at either the 7" Icon lift kit or the 8" Pure Performance lift kit. The 4.5" Icon lift kit will provide sufficient lift for the 40" tires with the COFF's. However, you get 50% more wheel articulation by going to the 7" Icon lift kit and the cost is basically the same.
I neither have the tools, a garage, or the skills to do the install of the gears and lift kit myself. So my goal is to try to minimize the installation cost by having everything done at one time. It's going to be one hell of a transformation but worth the wait to get it right the first time.
If you combine research and patience, then you will get exactly what you want with no regrets.
Old 10-01-2009, 02:33 PM
holupko holupko is offline
holupko is starting off with a positive reputation.
This is all good information, thanks. I agree about the research and hence my posting on this sight. While this discussion has progressed I've visited various sites for tires because it seems to me where the package will start. Tires first, rims to fit the tires, then lift to clear the pair. The following tires seem to be the most popular; Toyo Open Country MT, Nitto Terra Grapplers and Mickey Thompson MTZ. The prices are differnet yet close enough that I hold them on equal financial ground. Does anyone have an opion on longevity and performace of these tires? Or are there others I should consider? Thanks,
Old 10-01-2009, 02:45 PM
PERFORMANCE RED PERFORMANCE RED is offline
PERFORMANCE RED is starting off with a positive reputation.
Quote:
Originally Posted by holupko View Post
Performance Red,
Might you have a picture to share? Thanks,
Old 10-01-2009, 03:31 PM
Furian's Avatar
Those tires are excellent choices and are probably desired in the order in which you listed them.
Best All-terrain tires for Winter RedDevil460 1999 to 2016 Super Duty 59 02-01-2016 05:14 PM
Army Surplus Tire Help AmericanIron460 Offroad & 4x4 10 05-30-2015 12:29 PM
Lift kit for 35" tire UD_218 1999 to 2016 Super Duty 3 12-29-2013 09:52 AM
Need Tires, A Good 35" A/T or M/T. Help! seminaryranger 1999 to 2016 Super Duty 12 04-26-2011 09:56 PM
Educate me on tire/wheel choices jaspirr 1973 - 1979 F-100 & Larger F-Series Trucks 23 12-31-2009 05:49 PM
Tags
35, 350, 40, drive, f250, ford, gearing, lift, lifted, picture, pictures, required, tire, tires, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
