Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1948 - 1960 F1, F100 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1948 - 1960 F1, F100 And Larger F-Series Trucks Discuss The Fat Fendered, Classic and Box Style Ford Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-30-2009, 09:30 AM
kmacht kmacht is offline
kmacht is starting off with a positive reputation.
Rear Cab Corner with Gas Tank
Does anybody know of a company that sells the drivers side rear corner panel that includes the recess for the gas tank filler neck? Most of the cab corner in my 55 is rotted out. The gas recess is still in ok shape but it would be easier to just replace the whole section including a new recess rather than having to try and fix / blend in a new one. I have looked through a bunch of catalogs and everyone seems to sell the rear corner without the recess. Any suggestions?
Keith
  #2 (permalink)
Old 09-30-2009, 11:19 AM
jaye's Avatar
jaye jaye is offline
jaye is starting off with a positive reputation.
No one I know of sell them with the recess, since most people want to get ride of the under cab tank and move it under the bed. It shouldn't be to hard to cut the hole in one and use the two pieces that are spot welded to form the tunnel for the tank tube.
__________________
Jaye
  #3 (permalink)
Old 09-30-2009, 12:00 PM
cmoritz cmoritz is offline
cmoritz is starting off with a positive reputation.
Jaye, are you describing a method/plan.. of combining the original fuel fill opening ..with one of the new patch panel replacements? Like cutting out the original opening and mating it with the new panel for a stocker repair..mine was in great shape (the opening),..but I cut it out and tossed it in the scrap pile during panel replacement..
If I'm not mistaken,the inner panel/support behind the outer corner panel has a "dip" in it for the filler neck also...Good Thinking!
Options,options..always so many options...LoL!
__________________
MERTZ
  #4 (permalink)
Old 09-30-2009, 12:20 PM
jaye's Avatar
You are correct Mertz, the recess is only thing you will be missing mine was in great shape also but I tossed it to. After you weld in the new panel use the original one to place over it to mark the hole off the original panel. Once I broke the spot welds the outer portion just slid out, I'm sure you could fab it up using the pieces from an original, only the experts would be able to tell the difference, the rubber moulding would also give credit to it being original.
__________________
Jaye
  #5 (permalink)
Old 10-01-2009, 05:48 PM
Last Chance 56's Avatar
Last Chance 56 Last Chance 56 is offline
Last Chance 56 is starting off with a positive reputation.
You can check with Bitchin Products and they make many type of flush mounted gas doors but it would have to be welded in the replacement panel in your case.
Tags
1948 , 1958 , 1960 , cab , corner , corners , f100 , ford , gas , panels , patch , replace , tanks , truck , welding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
