5.0 to 5.8 swap
x2 what EP said.
But also...
If the '91 is an auto then you should get a "manual ECM".
Something about a "hanging idle" problem or something.
I'm still in the process of learning this stuff myself. :)
Alvin in AZ
But also...
Alvin in AZ
Yup, 351 firing order. #6 ends up being right at the front of the motor.
I assume the fuel pressure is OK since the 5.0 ran alright.
It's got headers, no O2 sensor, same as the 5.0.
I disconnected the vacumn line to the EGR (I assume this would keep it closed) because it used to connect straight to the exhaust manifold whereas the 5.0 had a tube running under the intake manifold somewhere.
The check engine light is now on but I have not checked the codes.
I was thinking of swapping in the sensors (TPS, temp, etc.) from the 5.0.
on
18 is the spout connector
33 is EGR
52 is power steering pressure
Ford Fuel Injection 2 Digit Self-test Codes 11-32
33 is EGR
