how big of a tire can i fit - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 09-29-2009, 04:32 PM
09f250hd's Avatar
09f250hd 09f250hd is offline
09f250hd is starting off with a positive reputation.
hey i have a question what is the biggest tire i can fit on my 09 f250 hd edition with no lift kit
Old 09-29-2009, 08:46 PM
jimd1050's Avatar
jimd1050 jimd1050 is offline
Worry later? IT IS LATER!
jimd1050 has a very good reputation on FTE.jimd1050 has a very good reputation on FTE.jimd1050 has a very good reputation on FTE.
Toyo Open Country MT's
I'm running 35X12.5R-17 Toyo Open Country MT's on 17X9 Helo HE842 wheels with no lift and no rubbing.
Old 09-29-2009, 08:53 PM
09f250hd's Avatar
Exclamation
idk if youre still on but i want to keep my stock hd wheels
Old 09-29-2009, 09:11 PM
09f250hd's Avatar
come on guys need help on this one
Old 09-29-2009, 09:27 PM
09f250hd's Avatar
how bout with a 2.5 leveling kit
Old 09-29-2009, 09:59 PM
seminaryranger's Avatar
seminaryranger seminaryranger is offline
seminaryranger has a good reputation on FTE.seminaryranger has a good reputation on FTE.
I'm trying out a set of 285/75/18 (35x11") in a day or two.
I'll be using the factory 18x8" rims.
Hopefully they'll fit.
Old 09-29-2009, 11:54 PM
dt75flh's Avatar
dt75flh dt75flh is offline
dt75flh is starting off with a positive reputation.
are you running 18" or 20" rims ?
with the 2" level kit (you do not need new shocks) you can run 35" tires
stock size on the factory 20" is 275-65-20 which is around 34 " tall
im running the factory 20" wheel and had 325-60-20 which is around 35.5 x 13 wide....
Im now runing toyos new mud 315-60-20 which does work better on the factory 8.5" wide rim...the other tires where a little too wide and I burned out the centers in only 32k miles..
Old 09-30-2009, 12:10 AM
jasfaa's Avatar
jasfaa jasfaa is offline
jasfaa is starting off with a positive reputation.
With the leveling kit you can run 37 x 13.50 18 with the right rim. Not sure if it will work with the stock ones. In the winter I have 35 x 12.50's 18 I put on my stock rims with studded tires. I only went with a smaller tire because I haul a camper and trailer that may rub my fender flares with the 37's on a good bump due to the weight. Without the flares I would not have worried about it. There was plenty of room.
Old 09-30-2009, 07:10 AM
Reave1's Avatar
Reave1 Reave1 is offline
Reave1 is starting off with a positive reputation.
I am running a stock 20" wheel with Nitto 325-60-20 which is equal to 35"x13.50"x20". I have a ready lift 2" leveling kit and the tires have no rubbing at all, even at full lock and going on alternating terrain. I reccomend this size tire because it will not leave you wanting more. It is the perfect size for the aggresive stance, but not looking like you shoe horned too much rubber under the wheel wells. Good Luck!!
Old 09-30-2009, 09:44 AM
jasfaa's Avatar
35's looked like they were too small on the truck. I actually had them go back and forth two or three times between the two tire sizes. 35's probably look fine on a truck without aftermarket fender flares but I have 18's instead of 20's as well.
Old 09-30-2009, 10:42 AM
TexMexF250's Avatar
TexMexF250 TexMexF250 is offline
TexMexF250 is starting off with a positive reputation.
I just put 35x12.5x20's pro comp extreme all terrains on my 08 HD CC 4x4 with facory HD wheels. In spite of what most tires shops told me (Tire Rack, 4wheelparts, NTB), they fit pefectly, no rubbing, and fill the wheel well much better. I too did not want to put a lift on my truck as I had on previous Fords. Forget the leveling kit, you don't need one to run 35's.
Old 09-30-2009, 11:43 AM
09f250hd's Avatar
thanks guys and yes i do want to keep my stock 20's but im debating on the 35's with no leveling kit or 37's with a 2.5 leveling kit and upgrading my shocks all the way around and maybe putting in the f350 blocks in the rear for extra hieght i like the nose high look just a little bit but not to high in the front
Old 01-25-2010, 10:16 PM
09f250hd's Avatar
ok finally got the 2.5 leveling kit with new rancho rs9000xl shocks and running a set of 37x12.50x20 nitto trail grapplers now got a major swaying prob in the rear end any body no how to fix that or whats causing it thanks there on the stock 20x8 hd wheels
Old 01-26-2010, 06:36 AM
Reave1's Avatar
The tire you got is most likely a load range D rather than E, therefore the sidewall strength of the tire is less. Also the max PSI should be around 50 cold. Combine those two factors and 37" of ride height and your gonna get a squirmy back end.
Old 01-26-2010, 08:53 AM
09f250hd's Avatar
no surprisingly there an E and the other prob with the tire pressure is the TPMS keeps going off I got them down to 60 im trying to go lower a little at a time thanks ille get some pics up once i figure out how to lol
09f250 blistien hd/5100 MarkSpillane66 1999 to 2016 Super Duty 1 04-28-2016 10:45 PM
How to identify an F250 HD Johnny L 1987 - 1996 F150 & Larger F-Series Trucks 73 12-09-2011 08:49 PM
Need pics - 97ish F250HD body style, stock - 4x4 with 255/85r16 tires ... eltacs 1987 - 1996 F150 & Larger F-Series Trucks 5 05-23-2010 09:40 AM
what size tires can i run on stock rims? tymann09 1987 - 1996 F150 & Larger F-Series Trucks 5 10-19-2009 11:27 AM
Will a 99-03 Manik brush guard fit on 1997 F-250HD? *keys* 1999 to 2016 Super Duty 4 07-15-2008 02:02 PM
Tags
08, 2009, 35, 350, big, biggest, f250, f350, fit, fitment, ford, lift, put, tire, tires, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
