how big of a tire can i fit - Page 3 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
  #31
Old 06-02-2011, 03:35 PM
bhalulko bhalulko is offline
bhalulko is starting off with a positive reputation.
I have a 2008 F-250 6.4L. Came with 265-70-17". I am looking to do the 2.5" lift in the front (with new shocks) and a 2" block in the back.
I need to step up my tire size- I'm looking at 315x70x17" tires on new 17x8.5 rims. Does anyone know if these will fit with the lift kit? How about without the lift kit?
  #32
Old 06-05-2011, 10:25 AM
Ronin 5729's Avatar
Ronin 5729 Ronin 5729 is offline
Ronin 5729 is gaining momentum as a positive member of FTE.
Ugghhh...I'm gonna sound like a broken record on this particular topic, kind of the way I do when it comes to tuning. Anyway, here goes...
Do NOT put 12.5 tires on a stock (8 inch wide) wheel. They are NOT the proper size, period. It doesn't matter how many people do it, that doesn't mean they're the right fit...sorry.
Just about every tire manufacturer has a "recommended rim/wheel width" specification on their website, and I couldn't fit a single one that recommended a 12.5 inch tire, never mind a 13.5 inch tire (?!?!?!) for an 8 inch rim.
Why does it matter? You may get it to fit (as obviously a whole lot of people here have) and it may look right, but you don't need to be a tire engineer to figure out you're putting a whole lot of sidewall stress on the tire by fitting it on a wheel that's too narrow. And if you tow (as I do with my '10 F250) you could be asking for all sorts of trouble.
That's definitely trouble I don't need, and although it seems a whole lot of tire shops don't seem to mind that they're fitting the wrong size tire on a rim they sure would care if there was a catastrophic malfunction/failure followed by a wreck...or worse...
That's when the "I read it was OK to do it on the internet" excuse would fall real short in a court, etc.
What will work? For stock 18s the Toyo Open Country A/T 285/75 R18 which, coincidentally, are double marked as 35x11.5 R18. The Open Country M/Ts are also available in the same size, and both tires are Load Range E rated, as they should be. I would not recommend a Load Range D tire on these trucks. That's a step down from stock and will give you all sorts of squirm with load. Not cool.
If you want a legit, unbiased, thoroughly researched and "court defensible" (!) answer to your question, call Tire Rack tech support @ 888-541-1777. They'll tell you exactly what you can (or can't use)...
Hope this helps...
  #33
Old 02-20-2014, 09:11 AM
Grizzly4x4's Avatar
Grizzly4x4 Grizzly4x4 is offline
Grizzly4x4 is starting off with a positive reputation.
Does anyone know if you need a lift to clear 35" on an 04? I'm not sure if the wheel wells are the same size. It seems like I need a 4", does that sound right? I'm thinking of getting Toyo Open country m/ts 35/12.5/17. How much back spacing would I need with a 17x8.5?
  #34
Old 02-27-2014, 02:55 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
I'm running 37x13.50R22 with a 2-1/2" kit in front, 350 blocks in the rear. Occasional rub.
  #35
Old 02-28-2014, 04:13 PM
finaddict's Avatar
finaddict finaddict is offline
finaddict is starting off with a positive reputation.
Hope this helps...
Ronin is right 12.5" wide tires on an 8" rim is not the correct match and not recommended. Even more so with a 20" rim vs. an 18" rim. Having said all that, I was not going to shell out and additional 2K plus for new rims and I like the stock aluminium rims so my combo is 35 x 12.5"x 20" Pro Comp Extreme all terrains on stock 8" x 20" rims and a 2.5" Ikon levelling kit, Firestone aribags and Torklift camper spring extensions in the rear.
I fit a 3000 lb. camper and tow a 7500 lb. boat on this rig and so far it has handled very well. No sway, some pretty rough terrain and tough roads in the wilds of B.C. and I am pretty happy with the results. They may not be the optimal (i.e. 10" wide rim with 12.5" tires), but it isn't far from optimal.
09f250 blistien hd/5100 MarkSpillane66 1999 to 2016 Super Duty 1 04-28-2016 10:45 PM
How to identify an F250 HD Johnny L 1987 - 1996 F150 & Larger F-Series Trucks 73 12-09-2011 08:49 PM
Need pics - 97ish F250HD body style, stock - 4x4 with 255/85r16 tires ... eltacs 1987 - 1996 F150 & Larger F-Series Trucks 5 05-23-2010 09:40 AM
what size tires can i run on stock rims? tymann09 1987 - 1996 F150 & Larger F-Series Trucks 5 10-19-2009 11:27 AM
Will a 99-03 Manik brush guard fit on 1997 F-250HD? *keys* 1999 to 2016 Super Duty 4 07-15-2008 02:02 PM
Tags
08, 2009, 35, 350, big, biggest, f250, f350, fit, fitment, ford, lift, put, tire, tires, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
