how big of a tire can i fit - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 01-26-2010, 10:31 PM
caprang's Avatar
caprang caprang is offline
caprang is gaining momentum as a positive member of FTE.
Tuning in for pics. I have a HD as well with factory 34 tall tires. Mine is a 350 so I already did the 2 in leveling kit and the 34's look small. So small that I dont think the 35's will be enough to look right. Lets see those 37's.
What is the recommended pressure on the tires themselves?
Old 01-26-2010, 10:34 PM
caprang's Avatar
09250hd, do you have a rear sway bar on your truck? I ordered my truck and had to order the sway bar as part of a package. I cant remember what else it came with but regardless, the point is that the rear sway bar was not standard equipment.
Old 01-27-2010, 12:30 AM
jasfaa's Avatar
jasfaa jasfaa is offline
jasfaa is starting off with a positive reputation.
I took the Ford one off and put a heavier duty one on. The stock one was kind of a joke.
Old 01-27-2010, 07:29 AM
caprang's Avatar
It is pretty wimpy but still better than nothing at all if thats what the OP has going on. Just a guess.
Jasfaa, could you feel the difference between them?
Old 01-27-2010, 08:00 PM
09f250hd's Avatar
09f250hd 09f250hd is offline
09f250hd is starting off with a positive reputation.
ill try to get some pics up tom cant figure out how to yet got any ideas or just copy and paste
Old 01-27-2010, 10:41 PM
caprang's Avatar
you can create a photobucket account. Then click 'go advanced' just under the reply section. There is an icon for inserting a picture there. You will need to copy and paste the URL of your photo there. i.e. go to photobucket, select your pic, copy the url, come back to FTE and post.
You can also add pics to your FTE profile and do the same thing. Go to your picture on FTE (like your avatar pic) click on properties, copy paste in your reply
There might be other ways but I use either of these myself
Old 01-27-2010, 10:57 PM
BigRed03 BigRed03 is offline
BigRed03 is starting off with a positive reputation.
I just changed my stock 275/70/18's out today for 285/75's. Went with the Toyo All Terrain....I think they look good. Had a 2" leveling kit put on the front as well. Still lots of room. Truck looks pretty mean now...Is it worth seeing if the dealer can re-calibrate speedometer to new tire size? I assume they could do this? From the 6.0 forum tech folder, look to be running 3.5mph faster at 70 MPH (actual 73.5) and the odometer will be off as well. Have to run the GPS and see. Probably not a big deal if I remember....
Old 01-31-2010, 08:12 PM
fg250's Avatar
fg250 fg250 is offline
fg250 is starting off with a positive reputation.
I'm running 305/50/20 on my stock wheels, the tires are General Grabber AT2's. They don't seem to work very well on snowy roads. I think because they are so wide. BUT... they LOOK cool and I think they will do well for off-roading.
Old 03-14-2010, 12:09 AM
TIRE FRYER's Avatar
TIRE FRYER TIRE FRYER is offline
TIRE FRYER is starting off with a positive reputation.
I have 37" toyo all terrains on my 08 with a 4.5 inch lift. I run about 45 psi in them with the tpms warning on all the time. Anybody have a fix for this yet? I would like to retain the tpms but would like it to read lower pressures. Anyone hear of different wheel sensors available, or in the process of being manufactured?
Old 03-14-2010, 05:56 PM
jasfaa's Avatar
Sorry Caprang, Ive been busy. Yes, you can tell a big difference but I haul a lot of weight which is when the stock one just wasn't up to it. if you don't haul a lot of weight, leave it alone.
Old 03-16-2010, 09:47 PM
Big Angry Hillbilly Big Angry Hillbilly is offline
Big Angry Hillbilly is starting off with a positive reputation.
FWIW -- the rear swaybar comes standard on Camper Package equipped trucks.
Old 03-16-2010, 10:54 PM
jasfaa's Avatar
I have the camper package. The stock sway bar is the width of my pinky finger. it was worthless with real weight.
  #28
Old 03-17-2010, 01:35 AM
09f250hd's Avatar
heres is the pic everybody has waited for lol
  #29
Old 03-17-2010, 08:25 PM
caprang's Avatar
try again, no pic
  #30
Old 03-17-2010, 10:07 PM
09f250hd's Avatar
i wonder what the deal is i can see it on my end but try this
Ford Powerstroke Diesel Forum
09f250 blistien hd/5100 MarkSpillane66 1999 to 2016 Super Duty 1 04-28-2016 10:45 PM
Max tire size for 4 inch lift (97 F250 HD) SeabastianMoroe 1987 - 1996 F150 & Larger F-Series Trucks 5 04-20-2016 12:00 PM
HD radio for 1976 F-250 Ozzie H. Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 11-22-2014 12:30 AM
Tire size help jhales91 1987 - 1996 F150 & Larger F-Series Trucks 2 10-02-2014 10:19 AM
HELP with spare tire jack R1punk 1987 - 1996 F150 & Larger F-Series Trucks 8 02-09-2005 01:18 PM
Tags
08, 2009, 35, 350, big, biggest, f250, f350, fit, fitment, ford, lift, put, tire, tires, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
