Truck Cap.. Interior mounting system?? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-29-2009, 09:41 AM
afonda's Avatar
afonda afonda is offline
afonda is gaining momentum as a positive member of FTE.
I want to mount / hang some items from the interior roof of my truck cap. I do a lot of fishing and need some extra storage space for my gear.
My cap is for a long bed and it is the extra tall kind. I was told it was made by the amish and it seems to be pretty heavy. The roof also seems to have an extra thickness to it.
I was thinking of drilling through the roof and mounting some 2x2's on the inside and then securing other items to that.
OR... I was thinking of using some Epoxy to glue the 2x2's to the inside of the cap.
Not sure which way is better.
How much weight would be too much weight for the roof to support?
Any ideas??
Old 09-29-2009, 09:55 AM
old ken old ken is offline
old ken is starting off with a positive reputation.
Why not just build a 2x4 frame to fit the inside of the cap? No drilling thru the roof. Then you can remove it when needed.
Ken
Old 09-29-2009, 10:59 AM
afonda's Avatar
Quote:
Ken
I thought of that, but not sure how to secure it.
Old 09-29-2009, 11:23 AM
bpounds's Avatar
bpounds bpounds is offline
2 bit Californian
bpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputationbpounds has a superb reputation
It's difficult to give confident advice without knowing the construction of the cap. Since you said it was made by the Amish, we can't even guess. Is it wood? Fiberglass? Injection molded?
In general, I would avoid penetrating through the cap, because of the likelyhood that it will eventually leak. If the roof is thick enough, like 1" or more, I would screw into, but not through, with wood screws. That should work with either wood or fiberglass.
If it is wood, epoxy can work very well, but you will need to sand through any finish before you apply the glue. Consider just gluing square blocks about 3" square of 3/4" high quality plywood like Baltic Birch. Then screw your rack to those blocks.
Another way to skin this cat would be to drill through the sides of the cap, into runners along each side, and then build your rack off those runners. If you must penetrate the cap, you will be better off doing it from the side so water will run away. Use some silicone and stainless steel fasteners. I would reserve this idea for fiberglass caps only. Wood swells and shrinks too much, and the penetrations will leak no matter what you do.
Old 09-29-2009, 11:50 AM
Just frame it up from the inside ledge of the cap and over the inside top, front and back. Use deck screws so you can unscrew to remove.
Ken
Old 09-29-2009, 01:25 PM
afonda's Avatar
The cap is fiberglass and the roof of it appears to be fairly thick, maybe an inch or so.
I think I am going to try the epoxy route. Its less bulky. My only worry is the epoxy coming loose and my gear falling all over the place...
Old 09-29-2009, 02:43 PM
bpounds's Avatar
2 bit Californian
I've never tried epoxy on FG, but I'll bet it will hold well. Just rough the surface up with some 60 grit paper and of course make sure you are through the paint if there is any.
Old 10-12-2009, 04:44 PM
svander svander is offline
svander is starting off with a positive reputation.
Check out a fastener call a Jack Nut. They work similar to a pop rivot or one of those dry wall anchors that spreed apart when you tighten the screw. They come in many different thread sizes. Fortunitly my work has a gun type tool to make them WAY eaiser to intall but I dont know where they got it. I'v mounted 20 rods and reels to my cap for a Canada trip I normally only have room for 10 but I added an extra rack for the trip. I've also mounted lights and eye bolts to hang stuff from. The last place I got them was Sears hardware. Your cap should have a double wall somewhere you just need to drill on the inside and there should be enough gap to get the Jack Nut in and get it pulled tight. Once its in you have a nut up in your roof now that you can attach any thing to. I passed the Jack Nut thru a fender washer first to give it more support and so it wouldnt bottom out in the hole. There is a similar thing made of rubber but they rot out over time. If I could send a picture I would but I cant figure out how to do it this is my first time on this site.
Installing Recon smoked LED cab lights 2009 f350 crew cab jroberts257 1999 to 2016 Super Duty 25 09-15-2013 12:18 PM
Patch Hole In Roof cbzdel 1999 to 2016 Super Duty 3 02-22-2012 08:02 PM
Picture of inside the cab with no headliner? hotrodtodd 1999 to 2016 Super Duty 4 12-12-2009 05:31 PM
Anyone sound deadened there truck? a-rod 1999 - 2003 7.3L Power Stroke Diesel 28 12-07-2008 02:36 PM
Attaching/Removing Roof Rack Rails Super Steve Excursion - King of SUVs 8 11-09-2007 12:54 AM
Tags
2002, attach, cap, f250, fiberglass, fishing, ford, hang, hardware, ideas, location, roof, support, truck, truckcap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
