292 V8 Front mount - Ford Truck Enthusiasts Forums
292 V8 Front mount
Old 09-28-2009, 09:12 PM
gthaustralia gthaustralia is offline
gthaustralia is starting off with a positive reputation.
Question 292 V8 Front mount
I have 1962 f100 short stepside and am restoring it. It was originally fitted with six cylinder and I now want to fit 292 v8. It appears to me that there should be a bracket welded an front x member of frame to accept front engine mount. Can some one let me know if this correct and is it possible to get dimensions or even a photo or can I buy part. I am from australia and would like contact in USA where I can buy used parts. Thankyou
Old 09-28-2009, 09:20 PM
john brown john brown is offline
john brown is starting off with a positive reputation.
yes there is a mount that welds to the crossmember at the front of the engine. when i did mine i cut the mount of the pick up i took the motor out of.
Old 09-30-2009, 10:45 PM
Thankyou for that . I was hoping I would get reply to rest of qustion,especially a contact in USA where I might be able to buy used parts.
Old 10-02-2009, 05:58 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Welcome to FTE
292:
There is an L shaped bracket (somewhat similar to the one for the I-6's) that bolts to the timing cover, then to the crossmember.
Welded to the crossmember is the "Engine Support Bracket" used in conjunction with the upper and lower rubber insulators.
These same two insulators (Upper: C3TZ6068D / Lower: C1TT6A061C) are used with 1961/64 F100/250 223/262 I-6's and 292's, and have been reproduced by Dennis Carpenter (denniscarpenter.com).
C3TZ6028A .. Front Engine Mount L Shaped Bracket / Obsolete
Fits 1961/64 F100/250 2WD/4WD 292.
BOWMAN FORD SALES in Bowman, North Dakota has ONE = 001-701-523-3257.
RED TAYLOR FORD in Corning, Arkansas has ONE = 001-870-857-3518.
KLIMESH MOTOR SALES in Calmar, Iowa has ONE = 001-563-562-3241.
C1TT5057E .. Engine Support Bracket / Obsolete
Fits: 1961/64 F100/250 2WD/4WD 292.
No Ford Dealer or obsolete parts vendor has any.
Old 10-02-2009, 04:30 PM
SJ Bikesaws's Avatar
SJ Bikesaws SJ Bikesaws is offline
SJ Bikesaws is starting off with a positive reputation.
It sounds like you have the 292 front mount already, right?
The cross member isn't anything special, just a straight beam of U-channel with a hole in the middle for the front mount bolt. the rubber insulators were just big rubber washers, I think I have used radius arm bushings from later model fords in their place. I am only suggesting this because the shipping to Australia will be outrageous, and unless you are going for show quality pristine, I don't think it would be worth it. If I remember I will snap a pic of the front for you this weekend.
Old 10-02-2009, 05:01 PM
There is absolutly no way that radius arm bushings could be used in place of the rubber insulators (engine mounts) used on 223/262 I-6's and 292's.
The center hole of the radius rod bushings is over twice the I.D. of the rubber insulators. The radius arm bushings are a totally different shape.
The radius arm bushings rubber material is also different.
The 223/262/292 rubber insulators are solid rubber with a hole thru the center used for the steel sleeve the bolt passes thru.
The upper insulator (C3TZ-6068-D) is tapered, the lower insulator (C1TT-6A061-C) has a shoulder on it.
I suggest you look at the Ford parts catalog illustration of the whole tamale to see what all this jazz looks like.
Why you didn't use the correct parts is beyond me. These parts were still available from Ford until a year ago.
Today, there are dozens still remaining at Ford dealers and at obsolete parts vendors.
These same front engine mount insulators (C1TT-6A061-C & C3TZ-6068-D) are also used for the rear engine (trans) mounts.
Two on the right and two on the left sides (one upper, one lower per side).
Old 10-03-2009, 09:09 AM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
Pictures of the one I had made are in my album. I might be able to find the dimensions. It's really not a very complicated piece to make.
Old 10-03-2009, 09:31 AM
RottenRon's Avatar
RottenRon RottenRon is offline
RottenRon is starting off with a positive reputation.
Front mount
G'day mate. I've got a 62 and a 65 that I'm working on. I live in Caboolture Qld., so I might be able to help you out with that mount or even some other bits.
Also, a good tip is to buy a set of workshop manuals on CD. You'll find em on ebay (USA). Mine cost me $49.99 (AU) delivered and it took 2 weeks.
Cheers, Ron.
Old 10-05-2009, 03:49 PM
Thanks : Would be interested in any parts you might have for sale. Please let me know.
292 vs 302, and value of 292 MCD46 1961 - 1966 F-100 & Larger F-Series Trucks 14 09-12-2016 08:08 PM
1960 F600 repower questions. Strumlute Large Truck 41 08-02-2016 12:24 AM
Need some help finding parts Trucker man 1961 - 1966 F-100 & Larger F-Series Trucks 14 02-15-2016 11:20 PM
Motor Swap Advice 64 Ford F-100 Bigfatsteve 1961 - 1966 F-100 & Larger F-Series Trucks 16 04-23-2014 07:29 PM
62 f250 engine swap question. sgettin 1961 - 1966 F-100 & Larger F-Series Trucks 2 01-12-2009 10:13 AM
Tags
1961, 1962, 292, 302, dimensions, engine, ford, front, locations, mount, number, photos, support, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
