Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > Kentucky Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Kentucky Chapter Join Chapter, Leader: CampSpringsJohn
  #1 (permalink)
Old 09-28-2009, 08:01 PM
Country705's Avatar
Country705 Country705 is offline
Garage is empty, add now
Country705 is starting off with a positive reputation.
Sas?
are any of you guys contemplating a sas swap on your 87-96 Ford F150 4x4's. I am thinking about doing one but i would want some one in kentucky to ask or talk to about it.
__________________
1994 f150 supercab 4x4
5.0 4r70w
Dual flowmaster Exhaust!
Kentucky Chapter Member
  #2 (permalink)
Old 09-29-2009, 04:42 PM
kenpobuck's Avatar
kenpobuck kenpobuck is offline
kenpobuck is gaining momentum as a positive member of FTE.kenpobuck is gaining momentum as a positive member of FTE.
Do you mean solid axle up front? If so it wouldn't be that hard. If you get one from a yard make sure to get everything that is under there.
__________________
DON'T BUY IT ..FAB IT!!!!
81 BRONCO 6.9 IDI, ARP headstuds, 3" dual straight pipes, isspro pyrometer, T18 4 Speed, 10.25 rear, d60 front, 4:10 gears, 37x12.5x16.5 wrangler m/t's (humvee takeoffs), 4" body lift. I am building the Bronco Ford should have!
  #3 (permalink)
Old 09-29-2009, 05:13 PM
Country705's Avatar
i guess so i have heard a few people over the 87-96 ford trucks forum talk about doing a solid axle swap from a 1977-1979 ford truck.
__________________
5.0 4r70w
  #4 (permalink)
Old 09-30-2009, 07:46 PM
kenpobuck's Avatar
If you find an 80's 250-350 with the solid front it would make it easier (except for the 8 lug part lol). The frames were the same so locatating the spring shackels is a snap. As for the lug thing the rear springs and axle are also a direct bolt in. The hevier rearends use the larger u-jionts like the Bronco but that is also easily fixed.
__________________
  #5 (permalink)
Old 09-30-2009, 07:56 PM
Country705's Avatar
Quote:
Looks to me like something i can look into lately. My truck either has to have a timing chain or a new distributor gear. so i am trying to get it back to running properly before i do anything suspension related.
__________________
5.0 4r70w
Tags
150, 1994, 8796, bronco, f150, ford, sas, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
