Bad front end vibration in 2000 AWD Mountaineer
My wife's 2000 AWD Mountaineer had a vibration in the front end (right side it felt like). The vibration started at about 60 mph and tapered off a little over 70 mph. I checked everything on the front end and the right wheel bearing had a good bit of play in it. I removed the hub and you could feel that the bearing was bad so I replaced it with a new hub and installed some new shocks as long as I was at it since her's were getting to be in bad shape. I test drove the vehicle after installing the new hub and the vibration is considerably worse, it seems as if all the play in the wheel bearing may have been damping the effects of the vibration and now with eveything tight the vibration is worse. I also rotated the tires at the same time I did the work, I'm going to rotate them back tomorrow to see if that has any effect on the problem. Any ideas what could be causing this vibration? Thanks.
Good luck,
George
FWIW, had situation like yours, followed all the routine diagnosis and repairs, removed wheel weights and installed beads (improved immensely) but still had shake intermittently.
Chased this condition for a yr, finally a tread separation condition showed up. Replaced tire set, lo and behold shake is history.
