Am I missing something bleeding the brakes? - Ford Truck Enthusiasts Forums
Old 09-28-2009, 05:44 PM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
there isn't anything special I need to do bleeding the brakes is there?
Put on the new calipers, and I have bled the whole way around 2 times, and still the brakes are barely there.
Old 09-28-2009, 06:05 PM
Talyn's Avatar
Hmm.
read some other old threads.
Is the Rabs bleeder on my truck?
I'd rush out and check, but then I'll be soaked.
At least I know how to bleed master cylidner without taking it out. i'ma do that. Mighta got to low.
Old 09-28-2009, 06:52 PM
Talyn's Avatar
okay, the rabs bleeder is there. wow that thing is small. was so worried that it would break. came out so easy.
Anyways.
Gravity bleeding the 4 right now.
Bled the master, had some air in there.
It's a pain to do in the truck, but its possible.
Old 09-28-2009, 07:08 PM
Talyn's Avatar
So not ever gravity bleeding for more then 5 mins, ever again.
Lost all my fluid out drivers front.
gotta rebleed the master.
grrrr. and i'm almost outa fluid.
Talyn's Avatar
Old 09-28-2009, 09:40 PM
Gobstopper909's Avatar
Gobstopper909 Gobstopper909 is offline
Gobstopper909 is gaining momentum as a positive member of FTE.
william you need some help bleeding them brakes. i have tried the speed bleeders and the "one person" bleeders as well but nothing kicks the air's a$$ better than the ol left foot. i always bled the right rear, left rear, rabs, front right, front left in that order. which you probly did but just makin sure.
did you check for leakys? one little seep will give you brakes for a few minutes on the road but quickly deplete your pedal
Old 09-29-2009, 06:41 AM
DZL JIM's Avatar
DZL JIM DZL JIM is offline
PREMIUM SPONSOR
DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.DZL JIM has a great reputation on FTE.
Do one wheel at a time. Take a small plastic Coke bottle fill it partially with fluid and run hose form bleeder to bottle, make sure hose sits in the fluid in the bottle. Fill Mast cyl, open bleeder and pump like hell onthe brake pedal. Stop and check to make sure it's not overflowing, then pump some more.
Keep mast cyl full and do 2 bottles worth at each wheel. Seems to work well for me. Actually even better than the 12v vacuum I used to use.
__________________
'96 F-350 Reg Cab 4x4 PSD
'05 F-250 6.0 cc 4x4
DZLJIM.com
Old 09-29-2009, 07:45 AM
rideracelivemx7's Avatar
rideracelivemx7 rideracelivemx7 is offline
rideracelivemx7 is starting off with a positive reputation.
only you can have a full out conversation with your self via the internet william lol
Old 09-29-2009, 09:10 AM
Talyn's Avatar
Oh I think i see what your saying.
Open it up and just pump the brakes by yourself. The fluid in the can will suck back in, so you'll eventually work all the air out if you keep doing it.
Last nights accident might have left me with no fluid to do that with.
I'll have to see.
I duno if i have any hose to do it with.
I'll just a Dr Pepper bottle too if you wanna know. *neener!!*
Vacuum bleeders are great, but suck in air.
I gotta bleed the master again I think. I'ma do that first, need somebody to help with that unfortunatly.
I was gonna bleed rabs and then the rears, but i'll do rears then rabs.
I was thinking air could get trapped in the rabs, so i'd bleed it first.
You should see me at home race, I talk to myself all day.
Old 09-29-2009, 09:57 AM
jeep1947 jeep1947 is offline
jeep1947 is starting off with a positive reputation.
I do the same thing William and I always get good answers from me. HA HA
Old 09-29-2009, 01:15 PM
Talyn's Avatar
Ooof, its cold out.
I think i got it though.
Old 09-29-2009, 10:08 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
[quote=rideracelivemx7;7981510]only you can have a full out conversation with your self via the internet william lol[/quote
x2, But I have to admit that I do my best work when I walk away and think about it (talk to myself).
bleeding brake master? good to doo 1973 - 1979 F-100 & Larger F-Series Trucks 6 02-03-2017 03:30 PM
Bleeding brakes with AE Headviking 6.0L Power Stroke Diesel 5 07-31-2011 12:27 PM
brake bleeding order jaye 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 04-29-2010 08:22 PM
Bleeding Brakes jleo Brakes, Steering, Suspension, Tires, & Wheels 6 04-04-2010 01:29 PM
97 f150 rear brake bleeding bheneee 1997 - 2003 F150 3 08-13-2009 05:24 PM
Tags
05, 1997, 250, 97, barkes, beeled, bleed, bleeding, brakes, break, deisel, f250, ford, rabs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
