friend talked me into putting Seafoam in my gastank - Ford Truck Enthusiasts Forums
Old 09-28-2009, 03:36 PM
kadrocker kadrocker is offline
kadrocker is starting off with a positive reputation.
My friend talked me into putting Seafoam into my gastank...WHOA!
My truck is smoking like a chimney now!
Good Lord- what's that crap doing to my truck!
Wish I never had put that stuff in there.
He also tried talking me into putting another can in my crankcase and straight into my carb.
Old 09-28-2009, 04:32 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150 Milwaukee1979F150 is offline
Milwaukee1979F150 is gaining momentum as a positive member of FTE.
It ok
what smoke color? White it normal. Why it smoke because you never done before first time it got.
It will go away if you drive long enough.
I have done many times on 79 F150, 01 F250, 96 E350, and many cars to list. It run great after pour sea foam in it.
Old 09-28-2009, 04:37 PM
slickrock01 slickrock01 is offline
slickrock01 is starting off with a positive reputation.
had a fella from marvel mystery oil talk me into that in my crankcase and gas tank, bottom dropped out of my mileage so I stopped after one time.
don't know if it would have gotten better but like you, the first time reaction was enough for me to say WHOA!
Old 09-28-2009, 04:45 PM
Milwaukee- it's white smoke. How often do you seafoam?
Old 09-28-2009, 05:08 PM
Quote:
hard to say
depend when I feel I need. Like I plan change spark plugs then I do.
mostly 5,000 to 50,000 miles then do sea foam. But sea foam is $8 so I do every 20,000 miles until mpg drop no reason then I use sea foam.
for engine in crankcase I don't use sea foam I use automatic transmission oil then pour 1 qts then put 500 miles on it then change oil. To get all sludge out.
Old 09-28-2009, 08:44 PM
compressorguy compressorguy is offline
compressorguy is starting off with a positive reputation.
The can into the carb will make it smoke like heck for a little while. Did you follow the directions on the can?. I use it all the time and have had nothing, but good results. It will knock loose all the deposits and blow them out the tail pipe as smoke.
Old 09-28-2009, 08:50 PM
Ds7776 Ds7776 is offline
Ds7776 is starting off with a positive reputation.
I put that stuff in the crank case of my big minneapolis moline tractor and WOW it cleaned the lifters out n everything else cuz it runs alot smoother.
Old 09-28-2009, 08:59 PM
460/5's Avatar
460/5 460/5 is offline
Zombie Survivalist
460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all460/5 is a name known to all
i do hope that the OP and the guy who used marvel mystery oil realize that that is how those two products work. white smoke from the exhaust=clean motor! thats all gunk and crap in there that being burned out. marvel, yes you will see a drop in fuel mileage while it cleans everything out. its just how the stuff works. did some seafoam in the intake of my 91 460 and turned the campus parking lot into one giant smoke cloud. im not even kidding, you couldnt see ten feet. then it smoked for about five minutes while i drove it around town. runs better now.
Old 09-28-2009, 09:02 PM
460/5's Avatar
Zombie Survivalist
you did read the can right? it says that when you do that, to do it in a very well ventilated area as fumes will be EXTREME.
Old 09-28-2009, 09:18 PM
I didn't think the smoke woule be THAT bad though! haha
My next door neighbors just love me! haha
Old 09-28-2009, 09:50 PM
msgross's Avatar
msgross msgross is offline
msgross is starting off with a positive reputation.
I used seafoam on my old chevy, I made a vacuum line drink it out of the can... do that when it's warm and let it sit for a while... then run the engine until it stops smoking... can't say if it helped much since the truck still ran like crap...
Old 09-28-2009, 11:09 PM
Motor Treatment - Sea Foam
watch the video, pretty handy these computers. to a point.
Fuel tank selection for relocation norfolknova 1961 - 1966 F-100 & Larger F-Series Trucks 8 11-18-2014 03:41 PM
Seafoam? tje2015 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 01-28-2012 06:37 PM
My new gas tank! SuperDuty93 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-06-2011 10:01 PM
Should I seafoam my 7.3L? gregorsway 1994.5 - 1997 7.3L Power Stroke Diesel 2 11-01-2010 05:43 PM
Seafoam... FordNFishinLover 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 18 06-29-2010 06:46 PM
Tags
1976, 460, 57, f150, f250, foam, ford, gas, hemi, oil, putting, sea, seafoam, sludge, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
