Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-28-2009, 11:30 AM
WALFORD'S 56's Avatar
WALFORD'S 56 WALFORD'S 56 is online now
WALFORD'S 56 is starting off with a positive reputation.
Question used 272 installed in 56...what oil for old engine?
Hi,
I know this question has been asked before....but the search is overwhelming.
I am installing a 272 from a 1956 f600 wrecker into a restored 1956 f100 and ready to fire her up.
I will most likely rebuild it if it all goes well next year.(over winter)
WHAT OIL? It has sludge in valve covers....and oil pan...and I cleaned those out.....but what oil to use? I am thinking 30weight non-detergeant.
WHAT WOULD YOU USE?
THANKS Bill
  #2 (permalink)
Old 09-28-2009, 11:43 AM
charliemccraney charliemccraney is offline
charliemccraney is starting off with a positive reputation.
Use your favorite brand oil in 10w40 or 20w50 and you should be alright.
  #3 (permalink)
Old 09-28-2009, 03:56 PM
GREAT....and hope this yblock lights right up....vrrrrrroommmBill
  #4 (permalink)
Old 09-28-2009, 03:57 PM
HT32BSX115's Avatar
HT32BSX115 HT32BSX115 is offline
HT32BSX115 is starting off with a positive reputation.
Hi Bill,
Yes, oil discussions here and on other sites is usually a "here's what I use" discussion.
In any old engine that may have had been run on non-detergent oil or maybe didn't have regular oil changes AND has a lot of sludge build-up, and then using detergent oil, there's always the risk of a piece breaking loose and plugging up an oil gallery.
Your cleaning it up a little will help but there's going to be a fair amount of area inside that you couldn't clean. It also helped to clean out the valve covers and oil pan and I presume that you cleaned the oil screen...
As Charlie indicated any brand will probably be just fine. All modern oils are "detergent" and will slowly dissolve the sludge that they touch as you run it and you'll remove most of it by changing it frequently.
The sludge that collects on the inside of the valve covers is mainly from oil vapor and that doesn't get removed very quickly. Splash oil will do it but it's a slow process.
your cleaning them took care of that!
I would suggest against using an oil "flush" system that uses a petroleum solvent in the oil since this can break loose large chucks of "stuff" and you can plug oil passages etc.....
You can clean the block when you tear it down for the rebuild!!!
Lets see some pictures!!
Cheers,
Rick
__________________
1955 F-600 // D I S C L A I M E R: No animals were injured while test driving my F-600 except the ones I RAN OVER INTENTIONALLY!!! (RESISTANCE IS FUTILE) 73 de Rick
  #5 (permalink)
Old 09-28-2009, 08:50 PM
Rick....I still cannot post pics.....it is way too complicated and way too much hassle to ask the wife.....LOL
Maybe after I paint her car....she will be a little more likely to help me....haha
Bill
Tags
272 , 600 , a1956 , clean , engine , ford , info , ohio , oil , older , set , sludge , timing , truck , trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
