Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator SPONSORED BY:
  #1 (permalink)
Old 09-28-2009, 08:31 AM
03BLKEB 03BLKEB is offline
Garage is empty, add now
03BLKEB is starting off with a positive reputation.
Replacing Struts on a 2003 Expedition
Thought I would see if anyone has advise or links to help with changing struts on our Expeditions? I have a 2003 with the regular (non air bag) suspension.
I found the link within the site : http://www.ford-trucks.com/article/i...Absorbers.html
anyone else have advise on this?
Thanks
  #2 (permalink)
Old 09-28-2009, 10:23 AM
alloro alloro is offline
alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.alloro has a great reputation on FTE.
Expeditions don't have struts.
__________________
To thank someone, click the left red "Add to Reputation" button
right of the word "permalink" top right of the poster's message.
  #3 (permalink)
Old 09-28-2009, 11:36 AM
Agreed, they appear to be shock absorbers to me, but for some reason people seem to keep calling them struts when I talk about it at a parts counter.
Given that the assembly does not have a built in rest / perch for a spring built in to the shock body (what i would consider a strut) I'll call it a shock.
Since I am looking for installation advice for putting the bilstein's on a 2003 Expedition, please share any install advice you may have.
Thanks for the clarification.
  #4 (permalink)
Old 09-28-2009, 08:19 PM
go_phx go_phx is offline
go_phx is starting off with a positive reputation.
Coil Over Shock Absorbers
They're called coil over shocks. Remove / replace is very similar to a strut. You need a spring compressor (a pretty heavy duty one at that) and the shock is removed out of the top of the coil assembly. I installed these Bilstein's on my 2004 F150...BE5-A761-H0 from eShocks.com. Not sure if your Expy is the same.
  #5 (permalink)
Old 10-02-2009, 05:25 PM
I was able to get the full set of Bilstein's delivered.
The rear's went in this afternoon without too much trouble. I found that i needed the following:
30mm socket
21 mm socket
15mm closed end ratchet wrench
17mm closed end offset wrench
6mm open end wrench
Spring compressors (needed a 15/16ths socket)
Hammer
PB Blaster
I found it helpful to remove the rear "tie rods" from the center of the rear of the vehicle to allow the A arms to articulate enough to remove the entire coil/shock assembly for easier replacement.
I'll be working on the fronts later this weekend, if anyone has advice please let me know, but it looks to be easier then the rear.
  #6 (permalink)
Old 10-06-2009, 08:21 AM
The only other item needed for the front was an allen key to hold the shock cylinder in place think it was a 5mm. Removed the front tie rods from the hub to allow removal of the assembly. Overall, easy to do, great improvement in handling and noticeable decrease in cabin noise.
  #7 (permalink)
Old 10-06-2009, 12:40 PM
AlbanyHDTV AlbanyHDTV is offline
AlbanyHDTV is starting off with a positive reputation.
How much did 4 Bilstein's cost for the 03 Expedition?
  #8 (permalink)
Old 10-06-2009, 03:07 PM
About $390.00, was hard to find in stock. I used Autowarehouse, but was not impressed with them at all.
  #9 (permalink)
Old 10-06-2009, 03:16 PM
Tire Rack has them for $351 incl tax & shipping, but the rears are backordered.
  #10 (permalink)
Old 10-06-2009, 03:42 PM
True, I was told they would start shipping backorder when they got their shipment around 11/15.
As much as I can work on the vehicles, I was not interested in working on the ground in NH with possible snow so I ordered with delivery as being worth the money.
  #11 (permalink)
Old 10-06-2009, 03:43 PM
By the way, Tire Rack is awsome, never had a problem with them.
  #12 (permalink)
Old 10-06-2009, 04:24 PM
My 03 Expy EB still has original shocks and I am noticing the wheels bounce after going over a bump. I have 75,000 miles and was thinking it was time to put new shocks on.
  #13 (permalink)
Old 10-07-2009, 09:36 AM
Totally recommend the installation. Not too hard to do, great benefits. i waited too long for sure.
  #14 (permalink)
Old 10-07-2009, 10:08 AM
04markIII's Avatar
04markIII 04markIII is offline
04markIII is starting off with a positive reputation.
i bought my expy w/69k miles. have 123k now in about 3 years. appears to be the original shocks all around. ride is rough, but i attribute most of that to the 20's. how is there less road noise?
__________________
2003 Expedition: 5.4L, Harley supercharger, 4lb lower pulley, c&l plenum, k&n panel filter, LFP SBTB, FTSP, removed front cats, Magnaflow 3" catback, Bilsteins, Eclipse AVN-5510, white face gauges, cobalt c2 boost gauge, 331 rwhp, 432 rwtq (dynoe'd w/20's, 17's back on now)
  #15 (permalink)
Old 10-07-2009, 10:30 AM
I found the ride to be springy (especially on offset turns like going in/out of a driveway) before the replacement.
I also tested on a washboard dirt round for about a mile. Before the replacement the truck was skittering across the road, with lots of noise and my 5 year old thought it was "bumpy fun".
After the ride was controlled and the truck stayed planted on the driving line without skittering at all - even with full, abs induced braking.
The reduction in road noise I can easily attribute to the shocks doing their job and absorbing the shocks, eliminating the road noise being transmitted straight into the cabin.
One of my other vehicles was updated to solid motor mounts and the cabin noise immediately went up. All vibration anywhere in a vehicle will get transmitted thru the chassis either motor or suspension. Since that vehicle spends more time in a performance role i did not care about the noise and for that application it was appropriate since the mounts needed replacing anyway - would never do that on the Expedition.
Tags
2003, 2005, 2006, absorbers, expedition, expedtion, ford, install, putting, replace, replacing, shock, shocks, strust, strut, struts
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
