1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Whats a good Lift Kit?
Old 09-28-2009, 02:48 PM
rickf92592's Avatar
rickf92592
rickf92592 is offline
size- height- rev/mile- rpm
LT275/65R18- 32.3- 649- 2500
LT315/70R17- 34.6- 601- 2315
LT37X12.50R17- 36.5- 573- 2207
Old 09-28-2009, 03:45 PM
kenny832's Avatar
kenny832
kenny832 is offline
I think I'll stick with 35" tires
Old 09-29-2009, 07:17 AM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
With 35" tires, you have two options:
Option #1 - Install a 2"-3" leveling kit (front) and 4" blocks (rear). New shocks are needed, which are generally included in the kit. This is the least expensive option.
Option #2 - Install a 4"-5" full lift kit. New shocks are definitely needed and are included in the kit. The kit most likely will have a drop pitman arm and/or an adjustable track bar. Some kits may include a 4-link upgrade for the front suspension. Also, you may want to upgrade the rear leaf springs. This option will definitely be more expensive.
Considering that you have a PSD engine, you shouldn't need to re-gear the axles for 35" tires. If you want to see pics of these configurations, go to http://www.trucktoyzperformance.com/...earch-blue.php and enter the appropriate search criteria. Here are a few examples from the website.
Option #1 - 2.5" Leveling Kit, 35" Tires, 20" Wheels
Option #1 - 2.5" Leveling Kit, 35" Tires, 17" Wheels
Option #2 - 4.5" Lift Kit, 35" Tires, 20" Tires
Option #2 - 4.5" Lift Kit, 35" Tires, 18" Wheels
Note: The larger 20" wheels significantly change the appearance in the pics above.
Old 10-01-2009, 01:27 AM
kenny832's Avatar
kenny832
kenny832 is offline
whats the difference between 4 links lift and a radius lift? Any lift I should absolutely stay away from?
Old 10-01-2009, 07:35 AM
rickf92592's Avatar
rickf92592
Go to Fabtech's website, you can see them all there.
Old 10-01-2009, 01:03 PM
Furian's Avatar
Furian
Furian is offline
In the simplest of terms, a "Radius" lift kit is one that has a single radius arm (like the OEM radius arm) where a 4-link lift kit has dual radius arms. The dual radius arms provide better adjustability and performance for off-road applications.
Single Radius Arm:
Note: While these aftermarket single radius arms look cool, I question how much value (if any) that they add to the vehicle.
Dual (4-Link) Radius Arms:
Note: The BDS 4-link radius arms above are not adjustable and therefore do not provide the full benefit of the design. Fabtech, Rize, and Icon offer fully adjustable 4-link systems. There may be others as well.
Old 10-04-2009, 01:38 AM
kenny832's Avatar
kenny832
kenny832 is offline
Ran into a guy today in a Lowes parking lot, he has a 4.5" lift and 35" tires on a crew cab long bed, says he gets the "wobble" at about 65mph.
anyone's ever heard or experience such thing??? If so, how to defeat the wobble and what lift kit will eliminate it.
thanks,
Old 10-05-2009, 07:37 AM
rickf92592's Avatar
rickf92592
Kenny,
With respect, there is a search feature on this website. All the questions you have been asking have been discussed many times before.
Old 10-05-2009, 11:42 AM
Furian's Avatar
Furian
Furian is offline
thanks,
Dual steering stablizers and/or alignment cams will address the "death wobble" in the late model Super Duties. Do a search using "dual steering stabilizer" and you find many threads on this topic.
Ford Truck Enthusiasts Forums - Search Results
Icon Alignment Cams:
Icon Vehicle Dynamics 2005-2008 FSD Alignment Cam Kit - Front Suspension Alignment Cams - Truck Toyz Store
Old 10-05-2009, 11:49 AM
Furian's Avatar
Furian
Furian is offline
Originally Posted by rickf92592
Kenny,
You're right Kenny! The "Search" feature is a great tool and should be utilized whenever possible. However, keep in mind that new perspectives and new product offerings are occurring all the time that will not be found in previous (older) threads.
Old 10-05-2009, 01:29 PM
brian42's Avatar
brian42
brian42 is online now
Originally Posted by cmcowboy
I have a 4" Fabtech and I have had just one problem with it ,just a little fibration at take off, I took the truck to a shop where they deal with lifts daily and they checked the truck over, drive shaft angle and so on. They could not find anything wrong. They told me there is allot of superdutys that are lifted that have this same fibration just at take off that no one figures out.
If it feels like a few little "clunks" in the driveline when you take off, it probably means that you need to grease the slip yoke in the driveshaft. That's the connection of the two piece drive shaft (covered by a rubber boot) between the carrier bearing and the rear differential. It is another one of Ford's "non-serviceable" joints (no grease fitting). If you do a search, there's plenty on it.
Old 10-05-2009, 02:52 PM
kenny832's Avatar
kenny832
kenny832 is offline
Thanks for all the help guys and thanks for the heads up on the search feature.
tyler.dunn94
06-27-2015 10:14 AM
T_Cooksey88
12-10-2014 08:02 PM
AppocAlexx
Offroad & 4x4
04-08-2014 03:23 PM
Etdesign
01-21-2013 11:31 AM
ALEXVB22
13
04-30-2008 05:55 PM
Quick Reply: Whats a good Lift Kit?
