Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Is F-150 Still King?
  #1 (permalink)
Old 09-28-2009, 12:33 AM
flipklos flipklos is offline
flipklos is starting off with a positive reputation.
Napa wires?
Does anyone know if a set of NAPA Belden wires will fit on my 292. My regular parts store has tried 3 different sets and none are long enough to prevent me from draging on my exhaust manifolds. dont want to lay out cash to have them burn up in a week.
  #2 (permalink)
Old 09-30-2009, 11:21 PM
64fordf100292 64fordf100292 is offline
64fordf100292 is starting off with a positive reputation.
I just used a set of accell custom wires and then just cut them to length. no burnt wires and look great. would think a set of sbf wires would work. that is if your going over the rocker cover. thats how i got mine.
  #3 (permalink)
Old 10-01-2009, 11:46 AM
HOTWRENCH HOTWRENCH is offline
HOTWRENCH is starting off with a positive reputation.
Talking Plug wires
If your routing the plug wires like the origionals a set for a brand C small block 57 vintage will work, or same engine 60's pickup will fit. I hate crossbreeding things but what works is the most important result. Wires are wires.
I hope this helps ----- Hotwrench
__________________
FERGUSON'S GARAGE est. 1967
car , truck , heavy equiptment repairs
4 X 4 specialists PORTABLE WELDING SERVICE
TOWING New @ used PARTS
1981 L 800 460 5 speed , 2 speed rear
1957 F 600 390 5 speed
  #4 (permalink)
Old 10-13-2009, 11:41 AM
ibuzzard ibuzzard is offline
ibuzzard is starting off with a positive reputation.
Concourse parts,in Reno Nevada has the correct length, black,original style wires for Y-Blocks.Steve.
__________________
"Who's offended?...Not I. ....You wanna offend me?Lower the truck,paint it titty pink,install a puny MustangII/PINTO front end,then come here and brag about it!"
Bill,a.k.a.NumberDummy
  #5 (permalink)
Old 10-14-2009, 11:28 AM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is offline
bigwin56f100 is starting off with a positive reputation.
Here is my .02$ worth. If you are not going to take the time to run the wires down and under like the originals, dont bother wasting your time and money.
The wires Steve listed from concourse will only fit if you run them the proper way, once again if you are not going to run them the factory way dont bother changing what you already have.
__________________
1956 Custom Cab Big Window. 272 Y block 3sp. See gallery. Kevin
  #6 (permalink)
Old 10-14-2009, 04:29 PM
You mean running the from the bottom?
  #7 (permalink)
Old 10-14-2009, 05:37 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is starting off with a positive reputation.
What about Accel cut to fit universal 8 mm? I have a set on, kind of routed in original fashion. They are under the manifolds and as close to the block as feasable. They work well and are resistant to burning through from exhaust contact. With Rams Horns the angled boot seems to work out OK.
__________________
1946 1/2 ton with Y-block
1964 F-250, 292 4 speeed
1990 Ranger 4WD
1954 Model 600 tractor
  #8 (permalink)
Old 10-14-2009, 06:57 PM
They are also about $70 a set.
Premium napa wires were $40.
Standard napa $25.
I have always used good wires. Accel wires at $70 are what I would use in a race car.
  #9 (permalink)
Old 10-14-2009, 08:18 PM
46yblock's Avatar
Yes I thought they may be that much. When I bought them they were 39.00, quite a while ago.
__________________
1990 Ranger 4WD
  #10 (permalink)
Old 10-15-2009, 09:02 AM
when i boutght my accel universal 8mm wires, they were aroung 40 bucks and that was about a yr and a few monthes ago.
  #11 (permalink)
Old 11-09-2009, 11:32 PM
Midnite Cruiser's Avatar
Midnite Cruiser Midnite Cruiser is offline
Midnite Cruiser is starting off with a positive reputation.
Quote:
46Y- is 'kind of' mean through the original style rubber blocks? Did you buy the 90 degree boots like stockers or the lower angle jobbers? I have stared at them on Summits site but could not bring myself to click!
__________________
Midnite Cruiser
'55 F-100
'64.5 Mustang Convert.
  #12 (permalink)
Old 11-10-2009, 06:26 AM
46yblock's Avatar
Quote:
I used 2 of the original pieces of routing hardware. The square or rectangle metal loop is on the ps engine corner, with 4 wires through it and coming around back of valve cover to dist.. One 4 wire rubber block is mounted at the engine rear 4-6 inches away from dist., handling the ds wires. The 8mm wires are diff to work into the rubber block, but I did it such that the wires are fairly tight between bloc and plugs. The block wouldnt completely close so it is held closed via the mounting bolt and two nuts. Used the 90 degree boots. It has worked allright, but there are probably guys with neater setups.
There weren't original wires to match length to, so several were cut a little shorter than ideal. Another big but inexpensive addition was to install the small plastic numeric id's on each wire close to dist.
The 4 or 5 dollars ended up saving a lot of time.
__________________
1990 Ranger 4WD
  #13 (permalink)
Old 11-10-2009, 11:13 AM
46yblock's Avatar
Midnight cruiser, given that you have done a slick instal on the toyota powersteering , wires should be easy.
__________________
1990 Ranger 4WD
  #14 (permalink)
Old 11-11-2009, 11:45 PM
charliemccraney charliemccraney is offline
charliemccraney is starting off with a positive reputation.
Pertronix has universal 7mm wire sets that will fit the stock hardware fine. I've used the dividers made by Made For You Products on custom brackets to support 8mm wires. Now I'm using yet another variation to hold 12mm wires. Both setups follow the original routing very closely. I think the stock routing is very clean looking.
Tags
belden , brand , napa , plug , wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
