95 f150 no spark - Ford Truck Enthusiasts Forums
95 f150 no spark
Old 09-27-2009, 09:48 PM
guyina4x4 guyina4x4 is offline
guyina4x4 is starting off with a positive reputation.
95 f150 no spark
I just bought this 95 f150, 4.9l, 5 sp
it has no spark
I was using a haynes manual to troubleshoot
I had the ICM tested and it's ok
it said to pull the plug from the ign control module and check the voltages on pins 2 and 3, 11.5 volts,in run position, then disconnect S wire and check voltage on pin 4, I have no voltage on pin 4 in run or start position.
I also put a test light on the white coil wire and get a light, it is supposed to flash when trying to start the engine, it does not flash, just stays on constant.
I should also mention, it looks as if someone has put in a new distributer, coil, ICM, plugs, wires, the works. the only thing not new is the ballast resistor or whatever the little round thing is under the coil(looks like a fat AA battery).
thanks for the help, I'm really lost here.
Old 09-27-2009, 10:32 PM
ok, i'm less confused but still no start
ok, so I was looking at half the wrong info in the haynes manual, I skipped a page.
I'll have to do some other tests tomorrow, as I did the wrong ones today. no wonder I was so confused.
any thoughts though will be greatly appreciated
thanks
Old 09-29-2009, 08:05 PM
thanks
thanks for all you help
I just thought I'd share the answer to the puzzle
if your pip tests higher than 8 volts ac or lower than 3vac
replace it
and again thanks for all your help
Old 10-03-2009, 06:34 PM
nikolass nikolass is offline
nikolass is starting off with a positive reputation.
I had a problem like that in my 88 4x4 5spd, it came up to be the yellow wire that goes into the relay on the drivers side by the test connector. It was all corroded and it was falling apart. The truck wouldn't spark and the fuel pump wouldn't prime. Not sure if that will help or not.
My 1995 F150 has lost it's spark jrb412 1987 - 1996 F150 & Larger F-Series Trucks 12 11-05-2010 04:15 PM
Engine Spins but No Start, No Spark g_k50 1978 - 1996 Big Bronco 21 10-11-2008 08:48 PM
No Spark 1989 F-150 Johnnykick Electrical Systems/Wiring 20 05-29-2007 11:30 AM
86 full size bronco not firing, please help!! shouldagotablazer 1978 - 1996 Big Bronco 48 03-01-2007 04:53 AM
Stalling / No start / Tach Jumping w/ key on / code 14 acc7484 Electrical Systems/Wiring 2 08-11-2005 11:22 AM
Tags
150, 1994, 1995, 94, 95, accessories, check, f150, ford, forum, spark, start, test, troubleshooting, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
