How to install a used Tommy Gate liftgate - Ford Truck Enthusiasts Forums
Old 09-27-2009, 06:35 PM
monckywrench monckywrench is offline
monckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to beholdmonckywrench is a splendid one to behold
I scored a used Tommy Gate (swap for a $30 notebook hard drive installation) and figured I'd share how easy they are to install. After using them at work I wanted one, and after Googling I found out that Tommy Gate makes installation kits for many different trucks.
The kit for a 2000 150 and similar trucks is TG-T250, which went for $140.14 from www.inlad.com. Shipping was ten bucks. It would be easy to fabricate the parts, but at that price I decided not to bother.
Tommy Gates are fairly common in salvage yards, are based on a few universal gates plus bracket kits, and can lift 1000 pounds or better. They are pretty simple and you can download manuals online.
I added lifting eyes to make handling easier:
Inside view:
Kit hardware:
Installed gate (note the stock hitch itself clears it but make sure your gate doesn't conflict with the hitch ball when you lower it).
There are more explicit installation photos in my gallery with detailed captions. If anyone has questions on pulling them from a donor truck or installing them feel free to ask. I'll add wiring pics later.
Old 09-25-2010, 12:44 PM
electryc_monk electryc_monk is offline
electryc_monk is starting off with a positive reputation.
Post Tommy liftgate "forgotten pic's?"
So - over a year later... no follow up posts, bumps or search-able pic's for this and the "wire job" you mentioned?
I guess I'm up the creek? Or did life happen to you as well for *this* project like several project's *got away* from me over the last 2 yrs?
It'll take me a few days to possibly a few weeks to get *spare time* to install mine.
Just acquired it via craigslist too.
Old 09-25-2010, 07:58 PM
I got lazy and have visions of mounting my spare Ramsey winch in the bed and sharing the power cable.
The wiring is extremely simple. All you need is the supplied breaker (100A) or equivalent run off a hot lead straight off the battery terminal or whatever terminal block you prefer, then run to the gate power cable.
I currently use a welding cable quick disconnect (ground is back through the frame) and a welding stinger to run it, or I grab a jumper cable. Put the MALE QD end on the lead that hangs out the gate, so the protected female will be on the hot side. I'll keep that arrangement when I hardwire it in. All the controls are self-contained in the gate. Works fine!
Looks like these, get at any welding supply:
Pearson SK-25 & BK-25 Dinse Connector Set Male & Female ( Set)
REMEMBER that later gates have a concealed switch you have to tap to activate power before the gate will cycle. Double-check your hydraulic reservoir and inspect everything, lubing as required.
Download manuals
here:
Welcome To Tommy Gate - America's First Name In Liftgates
The gate is insanely handy.
You can do the brackets first and leave the stock tailgate in place if you like. They install quickly.
I always anti-seize all hardware on principle.
If you don't have a welder handy, you could use a couple of eyebolts to lift the gate instead of welded eyelets.
Old 11-11-2010, 03:53 PM
garyhgaryh garyhgaryh is offline
garyhgaryh is starting off with a positive reputation.
You know, I've been following this for a year and I'm surprised no one followed up. I didn't post because I don't have a ford and didn't want to register. However, I did a search today and saw this post and I decided to post.
I'm on the duramax truck forum and no one seems to have a tommy lift on that forum.
I bought my Tommy lift last year. If waiting for the original owner to provide all the other stuff, I got the cold shoulder from him and decided to buy the bracket set for about $200, the breaker, and the welding wires.
Search the list and read your article with interest. It has to be the best one out there on self installing a tommy lift.
I search here one every few months to check on updates and there are none.
It's been almost a year since I bought mine and I need to install mine soon. Any help would be apperciated. My main issue is how to I hold up the tommy lift myself. I have an engine lift and a welder, but don't trust my welding skills.
BTW, where you located? I'm located in the Bay Area (CA).
Monckywrench: thanks for the informative post.
Gary
Old 11-11-2010, 05:16 PM
Spend some time doing welding practice. Prior to that, lurk and post questions at the weldingweb, hobart welding forums, and millerwelds forums. (Google those terms to get there.) Post pics of your welds for critique.
For a weld-free lift, drill a 5/16" hole dead center under where the welded eyelets are in my photos. Shove a bolt up through the hole and through a length of chain, then spin a nut down finger-tight. Repeat other side, then lift with engine lift.
Spin off nuts, and store the chain with the bolts going THROUGH it so they will be handy.
Chain, and chain grab hooks (I add them to everything I lift with) are mighty handy with an engine lift, so nothing you will use will go to waste!
Old 11-12-2010, 01:20 AM
thanks for the info about drilling the hole - so simple I didn't think of it. Well, I did think of it once but didn't think it would be strong enough to hold the entire lift. I was able to score a new G1 lift for $750, but I ended up spending about $300+ for parts so I'm not sure it was such a great deal afterall.
Gary
Ps. thanks for the link to the connector you use.
Old 11-12-2010, 08:50 AM
They last for decades, are very simple, and are a MAJOR backsaver. Using one can really change the way you use a truck.
Loading an engine, transmission, pile of block, bags of concrete, or fat chicks (put a donut in the bed so they lean towards the truck while lifting) will be much easier when you get it installed.
Old 12-12-2010, 12:27 PM
Mikelo Mikelo is offline
Mikelo is starting off with a positive reputation.
Brackets for lift gate
Would it be possible to use brackets for tommy lift from chevy 1500 on
ford 150? Or should it be done the "right way" and purchased for more then I paid for gate ?
Thanks
Old 12-12-2010, 02:21 PM
You see how the brackets sit from the photos (save them and zoom in or use Firefox with Image Zoomer for more detail if needed).
If you can get the same result, use whatever bracket you like. They are just steel plate, so you can cheerfully cut and weld them into whatever shape you want to try, and change that to something different if it no workee.
A slick way to mock up patterns is to use some white posterboard, by the way.
Old 12-12-2010, 07:03 PM
That's good to know. Im looking forward to instalation now. Thanks
Old 12-12-2010, 08:00 PM
Please post pics of the Chevy mounts BEFORE and after modding, in this thread, to help the next guy.
A liftgate is much nicer than back surgery.
Old 12-13-2010, 08:55 AM
I (embarrassing admitting now) still have the lift "sitting" strapped down in the bed- spare time went to foster kids we're getting ready to adopt, her boys(I'm step-dad entraining still, 5yrs later), fix the van's 2 O2 sensors, jetted axle DOJ & oil pan replacements, and work...... I came up with an idea to make the mounting even more DIY. Talking w/ my machine shop owning mentor on the structural integrity issues that could pose a "weak link" and so far I think we're a a few steps from starting final stage. This may have to wait till after the holidays -to be fare for both our lives and schedules (shrugs) -one ofthe trade offs for domestic life, I have learned- and continue to relearn on several fronts.
Old 12-13-2010, 09:37 AM
Lift gate on chevy 1500
Im not sure how to post pics(it asking for url and staff).
Here's a link to craigslist where I got it from:
Tommy Gate Hydraulic Truck Lift Gate
if someone can add these pictures to this topic, please do
cause it will be removed from CL soon. Thanks
Old 12-13-2010, 05:26 PM
Good score if you got it for asking price or under!
I'm wanting to scrounge or fab that platform section which folds out for extra width. They are a nice addition.
The Chevy brackets appear similar to the Ford. Should be a breeze to do.
Old 12-16-2010, 11:10 AM
It took couple of hours to install it in a shop. They welded hook as recommended above and attached brackets. All you need is right equipment in a shop. They charged me
$200. I think it worth it.
NSRA Northeast Nationals Show Pictures GreatNorthWoods 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 10-10-2012 09:46 AM
Have you looked under the front of your 2011 EB yet? jimmyb08SD EcoBoost (all engine sizes) 11 04-25-2011 10:30 PM
bear claw latch install `55 f100 thepitshop 1948 - 1956 F1, F100 & Larger F-Series Trucks 22 11-17-2010 12:17 PM
All Cleaned Up... WARNING Lots of Pics. cdrmotorsports 1999 to 2016 Super Duty 22 09-03-2010 12:02 PM
dirty/salty trucks i eat hybrids Excursion - King of SUVs 37 01-12-2008 07:07 PM
Tags
f150, ford, gate, gates, install, installation, installed, installing, lift, liftgate, parts, prices, tommy, tommygate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
