Foglamps with Highbeam Mod
2004 F250
Remove the 4 bolts and drop the fuse block, locate the large connector on the right side. Locate the light green/black wire and cut as shown. Connect a new piece of wire to the half coming from the fuse box and ground the other end. That’s it! The light's will work exactly as before except they will stay on when high beams are turned on.
