94 wont start
Old 09-29-2009, 08:51 AM
sleepyhead416's Avatar
sleepyhead416
sleepyhead416 is offline
94 wont start
Yesterday had a friend bring his 94 7.3 complaing hard to start (even on warm mornings) So i ck found 6 bad GPs & control box wasnt working fixed that truck started fine (cool) This morning he calls me says same thing WTF I asked if WTS light worked he said yes. So now I think fuel is draining off somewere is there any special place I should look??? TY
Old 09-29-2009, 08:53 AM
sleepyhead416
I also need to know how do u ck GP controler ?? Ground is good.
Old 09-30-2009, 12:54 AM
farmert's Avatar
farmert
farmert is online now
What brand of glow plugs were used? Some plugs have been knowen to burn out after just one or two uses. Motorcraft beru ZD9 are the ones to use in the 94. The return lines is a common place for air intrusion. It is very possible that the return line tees were disturbed when the glow plugs were installed. There are two orings under the tees on the injectors that get hard, and when the caps are moved it breaks the seal and the orings won't reseal.
Old 09-30-2009, 06:14 AM
sleepyhead416
Used autolite glow plugs. Nothing else was disturbed ... Is it possible injectors are leaking off? EV thing on top of motor & fuelpump are dry as a bone.
Old 09-30-2009, 08:54 AM
farmert's Avatar
farmert
what does the truck act like when you try to start it? Just turn overand not fire, or start, run for a few seconds then die? The wait to start light should stay on for at least 10 seconds when the engine is cold. If one or more glow plugs are bad it will make the controler short cycle. Autolight plugs have been known to burn out after just one time use.
Old 09-30-2009, 10:34 AM
sleepyhead416
U hit the nail on the head. 1DAY 2autolite GPs bad strange thing the tips were swelled up were a f er to get out. What was the brand ev1 are using?
Old 09-30-2009, 11:25 AM
farmert's Avatar
farmert
Motorcraft Beru ZD9.
Old 09-30-2009, 01:38 PM
sleepyhead416
I missed tht $5.60 deal !@#$ Now where?
