Go Back   Ford Truck Enthusiasts Forums > Bronco > Early Broncos (1966 - 1977)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Early Broncos (1966 - 1977) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 09-27-2009, 03:24 PM
gvrangr98 gvrangr98 is offline
gvrangr98 is starting off with a positive reputation.
Ford 5.0L 302....OIL...?
Every engine I work with uses a 5W-30 or 10W-30, unless it is a ford truck; they sometimes call for a 5W-20. What oil is suggested for the 5.0L 302 engine.(I am using a 4 barrel Holley Carburator.)
Thanks.
__________________
1998 Ford Ranger XLT 4X4 KingCab
Vulcan V6 3.0 Auto
K&N Cold Intake
2.5 in. CatBack
245/70r16 BFG OpenTrail T/A's
233,768 "New England" miles as of 11/17/08
  #2 (permalink)
Old 09-27-2009, 05:03 PM
Conanski's Avatar
Conanski Conanski is online now
1990 Ford F-150
Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE. Conanski has a great reputation on FTE.
10w30 is the oil to use for maximum durability and it is what Ford spec'd on these motors originally, they only lowered it to 5w30 later on in an attempt to improve fuel milage.
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55LS, Comp XE264HR-14, Flowtech LT's to 3" single, FRPP Mass Air Conversion, TweecerRT with BE, Innovate LC-1 wideband O2
  #3 (permalink)
Old 09-27-2009, 08:42 PM
Boba Fett Boba Fett is offline
Boba Fett is starting off with a positive reputation.
Conanski is right on. For most applications 10-30 is what you want to use.
  #4 (permalink)
Old 10-07-2009, 09:59 PM
Guapo XLT's Avatar
Guapo XLT Guapo XLT is offline
Guapo XLT is starting off with a positive reputation.
10W40 is normal. newer motors call for as low as 5W20 but i wouldn't use it on an older motor as it will go fast (ask how i know). i recently switched from 10W40 to 20W50 until i figure out where im losing oil through ( am not burning it ) on my ~'75 302
  #5 (permalink)
Old 10-08-2009, 03:32 PM
Beechkid Beechkid is online now
Beechkid is gaining momentum as a positive member of FTE.
I would also run either 5-30 or 10-30.... 5-30 is just going to flow on initial startup much faster to the bearings. 10-40 is a little heavy for a fresh engine with say less than 80,000 miles.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
Tags
02 , 10w30 , 10w40 , 302 , 4x4 , 50 , 50l , engine , ford , motor , oil , ranger , recommended , truck , weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
