460 EFI Ultimate Build - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-16-2014, 02:39 PM
saxxbills saxxbills is offline
saxxbills is starting off with a positive reputation.
Now that I have the writeup in my hand I noticed the torque converter. Oops. What were the specs for that? The part number seems to not exist and the Midwest people seem to not be much help. I have called them multiple times and they will not return my call.
  #32
Old 04-05-2014, 03:46 PM
Dbeast71 Dbeast71 is offline
Dbeast71 is starting off with a positive reputation.
Pics of your headers?
lesoster, you are the only person I've been able to find on google who has used those headers and I'm planning a similar build. Can I please get some pictures?
I think they will work on my 90 manual off-road rig but want to make sure before dropping the coin. Is the outlet 3"? Does it go over the transmission cross-member next to the frame (has to for my application)? If they fit like I think they will I won't even need an exhaust shop, just a piece of 3" pipe and a muffler.
Thanks
  #33
Old 08-24-2014, 01:47 PM
GuitarJesus's Avatar
GuitarJesus GuitarJesus is offline
GuitarJesus is gaining momentum as a positive member of FTE.
Thanks
The model for Leo's are for a California ODB2 truck. Different headers. For the 90' you should check Thorley's site.
  #34
Old 10-27-2014, 05:57 PM
GreenMachinee's Avatar
GreenMachinee GreenMachinee is offline
GreenMachinee is starting off with a positive reputation.
Quote:
Originally Posted by lesoster View Post
Unfortunately I do not have any photo's of my regulator install, but the BBK adjustable fuel regulator is an exact replacement for the stock fuel regulator. Simply remove the fuel line nuts from the stock regulator, remove the stock regulator and reverse the steps to install your new BBK adjustable rfuel regulator. The fuel pressure guage can be installed by removing a small brass plug on the body of the BBK regulator and installing the BBK fuel guage into the threaded port. It's Very simple.
In doing research I've found that the the 460 EFI performs best with the fuel pressure set @ 41 to 42 PSI, please refer to the magazine article in my original post.
Ler us know how the install works out.
Will that same regulator work on my 1990 F250 460?
  #35
Old 10-27-2014, 11:35 PM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
I have my uninstalled BBK 1706 in front of me and it says it is for the 86-93 5.0, but it is the exact same fuel rail mount as the 460. I just haven't installed it yet. It has the brass plug with it that lesoster talked about. I am installing mine along with my maf swap and setting it at 41P.S.I. to start with.
Bronco 460 Swap fordman153 1987 - 1996 F150 & Larger F-Series Trucks 4 10-09-2016 12:11 AM
Doug thorley header's question SatinBlack03 Modular V10 (6.8l) 15 10-02-2016 04:10 PM
Hello from Baton Rouge, LA cts2433 New Member Introductions 2 07-17-2016 07:42 PM
460 EFI performance help bl8ckb3ar 1987 - 1996 F150 & Larger F-Series Trucks 32 02-09-2014 04:42 PM
Anyone using a 61mm 3502 BBK Power-Plus Throttle Body eagle275 1987 - 1996 F150 & Larger F-Series Trucks 3 11-05-2013 12:16 AM
Tags
342555, 460, big, block, build, cam, comp, efi, engine, ford, motor, parts, performance, power, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
