Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-Atlantic Region > Pennsylvania Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Pennsylvania Chapter Join Chapter, Leader: Oldtrucknut7077
  #1 (permalink)
Old 09-26-2009, 01:06 PM
Microchudd's Avatar
Microchudd Microchudd is offline
1975 Ford F-100
Microchudd is gaining momentum as a positive member of FTE.
Couple of tech questions...
Greetings, all..
I need to pick your collective brains yet again.
I have two questions about my truck Question 1: Recently I've noticed that the
indicator bulb for my left turn signal... the little arrow in the dashboard that lights up doesn't work sometimes.. it wont flash then after like 20 minutes it will start to work again.
both the outside flashers work perfectly, there is just no indication of this in the truck cab.. loose wire or bad bulb?? if it is a bad bulb, how do i replace it?
and Question # 2: i also noticed that when i open my truck's tailgate and then go to close it i have to push in on the right side of the bed to get it to line up with the latch... My brother had it open one time and didn't shut it right and i didn't notice and now it wont line up.. frame trouble? when i replaced a leaf spring on the driver's side we had to use a come a long to get the axle pulled back into line.. could that be it? or do i need to realign the striker? Any help would be appreciated.
1975 Ford F100 Custom
  #2 (permalink)
Old 09-27-2009, 10:20 AM
Redcat Diesel's Avatar
Redcat Diesel Redcat Diesel is offline
1996 Ford F-150
My Garage
Redcat Diesel is gaining momentum as a positive member of FTE.Redcat Diesel is gaining momentum as a positive member of FTE.
The turn indicator could be a couple of things. A loose or cracked socket in the dash cluster or a loose connection at the cluster harness connecter would be the first places I would check. To access the cluster,
1) Disconnect the battery.
2) Reach up under the dash to the light switch. On top of the switch there is a spring loaded button. Push and hold the button then pull the switch **** and it's shaft out.
3) Pull the wiper switch and radio ***** off.
4) Remove the radio trim plate nuts and plate.
5) Remove the screws that retain the cluster trim panel and remove the panel.
6) Reach under the dash behind the speedometer and you'll be able to feel the spring clip that holds the speedo cable. Push the clip toward the speedo and pull the cable back at the same time.
7) Finally remove the 4 screws that retain the cluster.
8) Reverse these steps to reinstall everything. Be sure to push the speedo cable and light switch **** far enough to lock them.
Take a close look at that tail gate. It may be twisted from being slammed against a load.
__________________
Clay
96 F150, 72 F100, 69 F250, 67 F100
Pennsylvania chapter member
" Don't the girls all get prettier at closing time" - Mickey Gilley
  #3 (permalink)
Old 09-27-2009, 03:20 PM
Microchudd's Avatar
1975 Ford F-100
thanks...
Thanks a lot!!!
Ill have to tear that apart this week at work in our shop
I'll also take a close look at that tailgate.. he was slamming and banging around at it that day probably bent it ..
1975 F100 Custom
Tags
realigning, tailgate, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
